> $15.00 Magnetos
> $15.00 Magnetos
Original Posted By:> Michael D Cuy [SMTP:Michael.D.Cuy(at)lerc.nasa.gov]
Just called and ordered 2 mags They have over 100 left. Even if you neveruse them they are a great deal! BTW does anyone know if they are shieldedor non shielded? Or is the difference only in the wiring harness to theplugs?Steve EldredgeIT ServicesBrigham Young University> -----Original Message-----> Behalf Of Chad Johnson> Sent: Monday, June 21, 1999 11:25 AM> To: Pietenpol Discussion> Subject: $15.00 Magnetos>> Hello again group.>> I have had a large response to the magnetos I mentioned> earlier so I will post the source here. Yes they really are> $14.95 US. I sent a personal check to : Army Surplus> Warehouse, 635 w. Broadway, P.O. Box 1523, Idaho Falls, ID.> 83403, 208-529-4753. I opened one of mine and compared it> side by side with a Slick taken from a Cont. O-200. Most> part numbers are the same. Only slight differences in the> case. I talked directly with Slick and they confirmed the> quality. Niether they nor the supplier knows what type of> engine these mags fit but that it was most likely a GPU> (Ground Power Unit). They come brand new, sealed in the box.> For 15.00 bucks it might be worth your money to find out if> they would work for you. To be clear, I am not the supplier,> I just wanted to pass along a possible bargin. Let me know> what you think. Chad>> -----Original Message-----
