>> > > $15.00 Magnetos
>> > > $15.00 Magnetos
Original Posted By:>> > > Michael D Cuy [SMTP:Michael.D.Cuy(at)lerc.nasa.gov]
Just brought 4 new Slick Magnetos from these folks at 12:27pm Dallas time. Jakesays they still have over 100 mags left. Nearly 30 were sold earlier today.Slick model number is 4220Right rotation.$14.95 each Comes with mounting instructions etc..Mike KingDallas>Opps, before any one flames me, that should read "cables and plugs" ;-)>>Ken>>On Thu, 24 Jun 1999, Ken Beanlands wrote:>>> My understanding is that only the cables are shielded.>> >> Ken>> >> On Thu, 24 Jun 1999 steve(at)byu.edu wrote:>> >> > Just called and ordered 2 mags They have over 100 left. Even if younever>> > use them they are a great deal! BTW does anyone know if they areshielded>> > or non shielded? Or is the difference only in the wiring harness to the>> > plugs?>> > >> > Steve Eldredge>> > IT Services>> > Brigham Young University>> > >> > > -----Original Message----->> > > Behalf Of Chad Johnson>> > > Sent: Monday, June 21, 1999 11:25 AM>> > > To: Pietenpol Discussion>> > > Subject: $15.00 Magnetos>> > >>> > > Hello again group.>> > >>> > > I have had a large response to the magnetos I mentioned>> > > earlier so I will post the source here. Yes they really are>> > > $14.95 US. I sent a personal check to : Army Surplus>> > > Warehouse, 635 w. Broadway, P.O. Box 1523, Idaho Falls, ID.>> > > 83403, 208-529-4753. I opened one of mine and compared it>> > > side by side with a Slick taken from a Cont. O-200. Most>> > > part numbers are the same. Only slight differences in the>> > > case. I talked directly with Slick and they confirmed the>> > > quality. Niether they nor the supplier knows what type of>> > > engine these mags fit but that it was most likely a GPU>> > > (Ground Power Unit). They come brand new, sealed in the box.>> > > For 15.00 bucks it might be worth your money to find out if>> > > they would work for you. To be clear, I am not the supplier,>> > > I just wanted to pass along a possible bargin. Let me know>> > > what you think. Chad>> > >>> > > -----Original Message-----
