>>> > Staples in ribs
>>> > Staples in ribs
Original Posted By: CALLAIR(at)cybersol.com (Carpenter, Joel)
Earl- I had very good luck with the Arrow T25P stapler, which uses t25staples. These are the rounded staples that are used to staple 1/4 inchtelephone wire. The rounded crown sticks above the mahogany plywood, butstill gives plenty of clamping pressure for T-88 epoxy with good gluesqueeze. The nice thing about these staples is that you can then use anangled needle nose pliers to get under the crown and easily pull the staplesout without scarring the plywood. You can get this stapler at any largehardware store.Al Swanson>Sir;> Can yee tell me what that stapler type is? I have several over the years>but haven't found one that is totally acceptable...>Earl Myers>-----Original Message----->From: David Atnip >To: Pietenpol Discussion >Date: Tuesday, August 03, 1999 11:58 PM>Subject: Re: Staples in ribs>>>>You all may know this, but I found that they make a stapler like the one>used>>for ceiling tile, only this one is about 1/2 the size. I found it at a>local>>True Value Hardware. It works great. i did not pull my staples from the>wood>>because i thought like you . The varnish will seal the wood and staples...>>>>oil can wrote:>>>>> I've heard it both ways. I used staples for light clamping pressure with>>> t-88, then pulled the staples and pilot drilled w/#65 drill bit, then>used>>> nails.>>>>>> Lastly, if you staple, a good way is to put a narrow 050, or 035 shim>under>>> the stapler, then staple. That way the staple doesn't go all the way in>and>>> it's easier to pull out after the gussets set up.>>>>>> >From: "Craig L.Hanson" >>> >Reply-To: Pietenpol Discussion >>> >To: Pietenpol Discussion >>> >Subject: Staples in ribs>>> >Date: Mon, 02 Aug 1999 21:58:09 -0500>>> >>>> >I seen alot of ribs made with small steel or simular material left in>the>>> >ribs. I also seen at Brodhead a fuse. that had the same kind of>staples.>>> >I was told that these had to be taken out before the wood was varnished.>>> >When I asked at Oshkosh and Brodhead why they were left in the answer>was>>> >that when you varnish over them they would not rust. Is there any>comments>>> >on this?>>> >Craig Hanson>>>>>>>>>________________________________________________________________________________
