Original Posted By: fishin
>I bought my GN-1. I have a set of GN-1 plans. The printed plans call for>the front and rear cabanes being equal. Someone hand wrote that the rear>should be 1" shorter with a 2 degree angle of incidence. Someone at>Brodhead pointed out that the rear should be shorter. My plane does fly a>little tail low.>>Any thoughts or clarification?>>Ted>I have a set of original set of Aircamper plans, the cabanes show adifference of 1" front to back, for a wing incidence of 2 degrees. Theforward strut is 21 1/4", the rear strut is 20 1/4". I can send a scan ifyou wish, email me directly.Hope this helps.Dean________________________________________________________________________________
Pietenpol-List: GN-1 Cabanes
I bought my GN-1. I have a set of GN-1 plans. The printed plans call forthe front and rear cabanes being equal. Someone hand wrote that the rearshould be 1" shorter with a 2 degree angle of incidence. Someone atBrodhead pointed out that the rear should be shorter. My plane does fly alittle tail low.Any thoughts or clarification?Ted________________________________________________________________________________
Pietenpol-List: Re: GN-1 Cabanes
A GN 1 is NOT a Pietenpol. A Pietenpol has a slightly reflexed wing withpractically no nose down moment. A GN 1 has, I believe, a Cub wing, orsimilar, that has nose down moment. Don't start changing wing setup until youunderstand why you're doing it. On a Piet, changing the angle of incidenceshould not change the nose down moment (it won't make any difference in yourplane being tail heavy). I don't think it will on your GN1 either. It maymake it fly better, or worse.Where is your CG. Investigate that if tail heavy.MikeBellColumbia,SCMaiser(at)adena.byu.edu on 08/12/99 09:35:22 PMPlease respond to piet(at)byu.edu @ INTERNETcc:Subject: Pietenpol-List: Re: GN-1 Cabanes>I bought my GN-1. I have a set of GN-1 plans. The printed plans call for>the front and rear cabanes being equal. Someone hand wrote that the rear>should be 1" shorter with a 2 degree angle of incidence. Someone at>Brodhead pointed out that the rear should be shorter. My plane does fly a>little tail low.>>Any thoughts or clarification?>>Ted>I have a set of original set of Aircamper plans, the cabanes show adifference of 1" front to back, for a wing incidence of 2 degrees. Theforward strut is 21 1/4", the rear strut is 20 1/4". I can send a scan ifyou wish, email me directly.Hope this helps.Dean________________________________________________________________________________
Original Posted By: Replicraft(at)aol.com
Ted-As far as I know, the Cabane struts on the GN-1 are equal front and rear. The Pietenpol struts are 1" shorter ...The weight and balance could be your problem....try a 50 lb. weight in the front seat while flying solo.Steve________________________________________________________________________________
> Re: GN-1 Cabanes
Original Posted By: Greg Yotz
Steve,please use a last name or city or something to identify yourself. I amgetting confused about my, I mean your posts....Thanks,Stevee, stevee, steve E. or,Steve EldredgeIT ServicesBrigham Young University> -----Original Message-----> Replicraft(at)aol.com> Sent: Monday, August 16, 1999 6:59 PM> To: Pietenpol Discussion> Subject: Re: GN-1 Cabanes>>> Ted-> As far as I know, the Cabane struts on the GN-1 are equal> front and rear. The> Pietenpol struts are 1" shorter ...> The weight and balance could be your problem....try a 50 lb.> weight in the> front seat while flying solo.>> Steve>>________________________________________________________________________________
