Pietenpol-List: direct drive corvair
It seems that the corvair is rated @ 110 hp. But if you check the specs,that hp is at about 4500 rpm. Can't run that length prop at that speedso when it's run at , say 2500 rpm , the hp is GREATLY deminished.Not my data , but Dicks. I think that these run at about 3800rpm ( Ithink)waltIt seems that the corvair is rated @110 hp. Butif you check the specs, that hp is at about 4500 rpm. Can't run thatlength propat that speed so when it's run at , say 2500 rpm , the hp is GREATLYdeminished.Not my data , but Dicks. Ithink thatthese run at about 3800rpm ( I think)walt________________________________________________________________________________
