Pietenpol-List: Antenna / ign. noise
Original Posted By: L_Prange(at)ix.netcom.com
Gene Tomblin: Just how bad is noise from the unshielded ign. leads? UMAInstruments makes a spark plug impulse sensor tachometer. However thesensor will not work if you have metal brad shielding on the ignitionwires. this looked like another way to eliminate a couple of pounds oftach cable for the weight conscious "A" builder. Also, plain wire wouldsave weight as well. Thank you. Leon Stefan________________________________________________________________________________
Pietenpol-List:
Original Posted By: COZYPILOT(at)aol.com
UNSUBSCRIBE PIETL_Prange(at)ix.netcom.com________________________________________________________________________________
