Hey Guys, I thought since we were on the subject of the FAA, I would pass along the attached advisory circular. If you have Microsoft Word (version 6.0 or newer) you should be able to download it and open it right up. I recommend that everyone print yourself a copy for reference. In most cases it will send you off in the right direction for at least the common questions that may come up. For those of you who are inexperienced with Advisory Circulars, they are FAA supplemental information which do not supersede FARs but are intended to provide guidance for an acceptable means of compliance to the regs. They are not the only acceptable means...but one that has already been blessed by the FAA. There is a lot of helpful information in this one for CERTIFICATION AND OPERATION OF AMATEUR-BUILT AIRCRAFT. If anyone has a specific need to locate a particular FAR, AC, TC, STC, AD, TCDS etc..., let me know and I will grab it off of the system at work and forward to you. We have the subscription with all of the latest updates. I hope this is useful to some of you. Terry (CDT)________________________________________________________________________________
