Pietenpol-List: Center Brace Wire Ftg.
Subject: Center Brace Wire Ftg. In the plans it says that the metal fittings should be made of 12guage metal. It seems that it is quite heavy. Am I reading this wrong. I am assuming that 12 guage is .100 ". Is this correct and is this thesize that others have used? Craig Hanson from North Dakota Craig & Shari Hanson________________________________________________________________________________
Original Posted By: Copinfo
In the plans it says that the metal fittings should be made of 12 guagemetal. It seems that it is quite heavy. Am I reading this wrong. I amassuming that 12 guage is .100 ". Is this correct and is this the sizethat others have used?Craig Hanson from North DakotaCraig & Shari HansonIn the plans it says that the metal fittings shouldbe made of12 guage metal. It seems that it is quite heavy. Am Ireading thiswrong. I am assuming that 12 guage is .100 ". Is thiscorrect and isthis the size that others have used?Craig Hanson from North DakotaCraig Shari Hanson________________________________________________________________________________
Pietenpol-List: Re: Center Brace Wire Ftg.
Original Posted By:> "Craig L.Hanson"
Going from memory, and not having the plans in front of me, I think the plans callfor 13 ga. on the hinges, control stick lugs, etc., which is about 0.090". It sure looks about right to me...> Date: Tue, 31 Aug 1999 19:31:21 -0500
Original Posted By: Craig L.Hanson
Craig; I used .i to .125 when 12ga. was called for depending on where it wasused.....earl myers -----Original Message-----
Subject: Pietenpol-List: Re: Center Brace Wire Ftg.I used .090 on mine and I feel this is PLENTY strong enough.Greg Cardinal>>> "Craig L.Hanson" 08/31 6:31 PM >>>In the plans it says that the metal fittings should be made of 12 guagemetal. It seems that it is quite heavy. Am I reading this wrong. I amassuming that 12 guage is .100 ". Is this correct and is this the size thatothers have used?Craig Hanson from North DakotaCraig & Shari Hanson________________________________________________________________________________
Pietenpol-List: RE: Center Brace Wire Ftg.
Original Posted By:> William C. Beerman[SMTP:wcb(at)bbt.com]
12 Gauge is .105 inch according to the chart I have gotten of the internet. Seemslike it varies from chart to chart by a few thousandths. AS & S has .100inch available. I used whatever the plans called for, and went with whatevercame closest to the gauge thickness. Bart D ConradBoeing Field ServiceDC-9/MD-80/DC-10 & 737 Heavy MtcPhone: 713-640-5882/713-324-4192Fax: 713-640-5891Pager: 713-318-1625> ----------
I used .090 on mine and I feel this is PLENTY strong enough.Greg Cardinal>>> "Craig L.Hanson" 08/31 6:31 PM >>>In the plans it says that the metal fittings should be made of 12 guagemetal. It seems that it is quite heavy. Am I reading this wrong. I amassuming that 12 guage is .100 ". Is this correct and is this the sizethat others have used?Craig Hanson from North DakotaCraig & Shari Hanson________________________________________________________________________________
Craig-There is a chart somewhere in the world that converts guage to decimal. The material thickness for our wing fittings are as follows:Outer strut and cabane attach- .090 4130Drag wire attach- .065" 4130Pulley assembly- .065" 4130SteveReplicraft Aviation________________________________________________________________________________
The original prints were calling out 1010( I think) steel which is not asstrong as 4130. In the newer three piece wing print, which calls out 4130 ,call out .080"walt-----Original Message-----
There are several charts to convert gage to decimal thickness for sheetsteel. It is not real clear which chart should be consulted. To addfurther confusion, if you look through any supply catalog such asDillsburg, Wicks or Aircraft Spruce, you will find that availablethicknesses of steel do not follow ANY gage to decimal chart.So, I made up my own:>>> 09/01 1:46 PM >>>Craig-There is a chart somewhere in the world that converts guage to decimal.The material thickness for our wing fittings are as follows:Outer strut and cabane attach- .090 4130Drag wire attach- .065" 4130Pulley assembly- .065" 4130SteveReplicraft Aviation________________________________________________________________________________
Original Posted By: Greg Yotz
Page 362 Machinery's Handbook 24th edition has the chart for sheet metalgages. For steel10 gage .134511 gage .119612 gage .104613 gage .089714 gage .074715 gage .067316 gage .059817 gage .053818 gage .047819 gage .041820 gage .035921 gage .032922 gage .0299If you are using galvanized (firewall), the decimal equivelant isdifferent.Replicraft(at)aol.com wrote:> Craig-> There is a chart somewhere in the world that converts guage to decimal.> The material thickness for our wing fittings are as follows:>> Outer strut and cabane attach- .090 4130> Drag wire attach- .065" 4130> Pulley assembly- .065" 4130>> Steve> Replicraft Aviation________________________________________________________________________________
Original Posted By: GREA738(at)aol.com
hello !please delete me from the mailing list.thank you________________________________________________________________________________
Original Posted By:> > "Craig L.Hanson"
