> Battery Box.
> Battery Box.
No, I'm still finishing my first. It's about to go into it's 9th year thismonth! However, we're about a third of the way through thte covering andall the structural work is done. The engine is on it's was and life isfood ;-). Should have the fabric done by the end of Nov and then it's onto the systems (what few there are). So far, the fabric has certainly beenthe most fun and most rewarding and the assembly of the fuselage structureranks second. As for the box, despite the new advances, I still have to mount it in theplane somewhere and a ply box is the best way to go, even if it's just toprotect the contacts from shorting out (the battery will be in the baggagecompartment area). Even these new batteries can still crack and there isalways the possibility of leaks so I'd prefer to be safe.KenOn Thu, 23 Sep 1999 mbell1(at)columbiaenergygroup.com wrote:> Ken,> > Are you building a second Christavia? Check out new battery technology.> You can get much smaller batteries these days that don't outgas or leak. All> of my electrical stuff is at home and I'm 500 miles away at work, but check out> some of the on-line electric and battery sites. You are going to have a lot> of feet of very heavy #2 wire otherwise.> > Mike Bell> Columbia, SC> > > > > > > Maiser(at)adena.byu.edu on 09/22/99 06:03:41 PM> Please respond to piet(at)byu.edu @ INTERNET> > > To: piet(at)byu.edu @ INTERNET> cc:> > Subject: Battery Box.> > The plans for the Christavia show the battery on the firewall. However,> that will put the CG too far forward. So, it's going behind the rear seat.> That means that I'll need to build a battery bbox to store it in. I'm> thinking of building it out of 1/4" ply with fiberglass inside and out.> The question is simple: How resistant is West System resign to battery> acid? Is there a good coating that I could use in the box to seal it in> the case of a leak? What do you Piet guys do?> > Thanks,> > Ken Beanlands B.Eng (Aerospace)> Calgary, Alberta, Canada> Christavia MK 1 C-GREN> > > > Ken Beanlands B.Eng (Aerospace)Calgary, Alberta, CanadaChristavia MK 1 C-GREN________________________________________________________________________________
