Pietenpol-List: 1/2x1/2 diaginals question
The 1/2x1/2 bracing in the wing, such as at wing tip ,at aileron cut outetc. The plans show a top view only, is this bracing at the centerline, or is it to top and bottom of spar?waltThe 1/2x1/2 bracing in the wing,such as at wingtip ,at aileron cut out etc. The plans show a top view only,is thisbracing at the centerline , or is it to top and bottom ofspar?walt________________________________________________________________________________
Pietenpol-List: Re: 1/2x1/2 diaginals question
Subject: Pietenpol-List: Re: 1/2x1/2 diaginals question>Center.>>John Langston>> writes:>>The 1/2x1/2 bracing in the wing, such as at wing tip ,at aileron cut>>out etc. The plans show a top view only, is this bracing at the>>centerline , or is it to top and bottom of spar?>>walt>>>________________________________________________________________________________
Center.John Langston writes:>The 1/2x1/2 bracing in the wing, such as at wing tip ,at aileron cut >out etc. The plans show a top view only, is this bracing at the >centerline , or is it to top and bottom of spar?>walt__________________________________________________________________________________________
It goes to the middle of the spar and it is corner blocked to avoid the endgrain joint from not stickingEarl Myers-----Original Message-----
