Pietenpol-List: scallop leading edge ply?
Original Posted By: Craig Hiers
Original Posted By: GMalley(at)aol.com
Are you guys scalloping the leading edge ply at the back, between the ribs?My first project called for this, and it made the fabric lay nice. Said nomention of it in the plans, and wondered what you guys did.walt evans________________________________________________________________________________
Re: Pietenpol-List: scallop leading edge ply?
Original Posted By: Lawrence V Williams
Subject: Re: Pietenpol-List: Re: wing const. knots to itI covered my root ribs the same way with plywood so that it would be easier to attach the fabric. Knowing that the fabric would pull on the ribs, I also attached 2 inch wide plywood to the undersurface of the root ribs. After tautening, it still bowed in nearly 1/2 inch.Jim Malley________________________________________________________________________________Date: Wed, 3 Nov 1999 19:31:08 -0500Subject: Re: Pietenpol-List: scallop leading edge ply?
Original Posted By: "Jack Phillips (EUS)"
Subject: Re: Pietenpol-List: scallop leading edge ply?In a message dated 11/3/99 6:33:19 PM Central Standard Time, lnawms(at)juno.com writes: >Are you guys scalloping the leading edge ply at the back, between the >ribs? > Walt Mr. Pietenpol said not to scallop it, just glue it down as the plans call for and DON'T attach it to the top of the spar. It will pull down a little between the ribs as the fabric shrinks and give you a nice transition. Larry >>I did it the way the plans call for, but was concerned that scalloped ply might have been the better way. It turned just the way Mr. Pietenpol said it would, and I'm very pleased with it. However, I did bevel the top aft corner of the plywood just a little, so the fabric could roll off of it, as opposed to a sharp break.Chuck G.________________________________________________________________________________
