Original Posted By: Ron Butcher
Subject: Re: Pietenpol-List: Rudder and Elevator hingesChris,At Brodhead, last August, Vi was still offering the hinges. I'll look up his address if you need it. I'm using his hinges, and they seem to be prety nifty. Aside: I'm in Fairfield, just a short Piet flight away from you, maybe we can get together to compare notes some time. I'm just beginning my project, ribs are done, rudder is built, and have some bits and pieces. Drop me a line at ADonJr(at)AOL.com if this sounds interesting to you.Don Cooley, Fairfield,CA________________________________________________________________________________Date: Sun, 13 Feb 2000 19:00:46 -0800
Chris,Vi Kapler's address:1033 Forest Hills Drive SWRochester, MN 55902507 288-3322I sent him a check for $35 and it will be the best $35 that you'll spend on the whole project! I got mine from him about 3 months ago. You'll need to do some filing to clean them up, but I've got them mounted on my Fin/Rudder so far, and they seem fine and definitely save some work!Good Luck!Gary Meadows________________________________________________________________________________
