Pietenpol-List: Piet shock struts.
Original Posted By: Replicraft(at)aol.com
Subject: Pietenpol-List: Piet shock struts.I need to know what size the head shock strut tube is and the size of thelower shock strut tube so I can start building the shock/bungee shocksystem. I only have the 1933 flying & glider mag and theres nothing inthere about building the shock tubes.SteveSteve W - Pietenpol in construction!GN-1--<(next project).IHA #6________________________________________________________________________________
Re: Pietenpol-List: Piet shock struts.
Original Posted By: Greggotone(at)aol.com
Subject: Re: Pietenpol-List: Piet shock struts.Steve-I thought you said you were using a Cub gear...I assumed you had the assembly and were trying to attach it.I have drawings of the original 1934 split gear, but I would have to photo-copy it, add some notes and snail-mail it to you.Send me your phone number, and I'll call you. I scanned the j-3 gear , but AOL won't e-mail files larger than 16kb.Steve________________________________________________________________________________
Original Posted By: "Michael Hinchman"
Subject: Re: Pietenpol-List: Piet shock struts.I have the cub gear but I am trying too build my own spring gear usingsprings instead of bungees. I am trying too figure out how too use yourparts too mount the cub gear but so far I can only use the pads and thearco sports parts. I am going too attach the upper spring tubes andattach the lower spring tubes to the original cub mounts so I will havetoo send the mounts you sent back as I am going too make my own for thetop.The cub pictures will be most handy too be sure.Steve> > Steve-> I thought you said you were using a Cub gear...I assumed you had the > assembly > and were trying to attach it.> > I have drawings of the original 1934 split gear, but I would have to > > photo-copy it, add some notes and snail-mail it to you.> > Send me your phone number, and I'll call you. I scanned the j-3 > gear , but > AOL won't e-mail files larger than 16kb.> > Steve> > > > > Steve W - Pietenpol in construction!GN-1--<(next project).IHA #6________________________________________________________________________________
