Pietenpol-List: spoked wheels
Original Posted By: Mary & Paul Winkworth
I'm sitting here still in sticker shock. I just went to a Harley dealer allset to order a set of shiney new spoked wheels. With tires that was $450each. It's time to re-group and start searching the junk yards. I calledBuchanens in CA. for their list. Does anybody know a reasonable source forwheels?Dick Navratil________________________________________________________________________________Date: Mon, 06 Mar 2000 20:31:59 -0500
> Re: Pietenpol-List: spoked wheels
What size kawasaki wheel hub would you use ?Bob>From: Warren Shoun >Reply-To: pietenpol-list(at)matronics.com>To: pietenpol-list(at)matronics.com>Subject: Re: Pietenpol-List: spoked wheels>Date: Mon, 06 Mar 2000 17:32:13 -0800>>>Richard,> Having done this backwards once, allow me to make these suggestions:> Pick the size, make and type of tire and tube that you want to use >first. Then>have your local cycle shop point you in the direction of a cycle salvage >shop/yard>(mine wasn't listed in the phone book!). I got 2 Honda 90 front wheel, >brake & axle>assemblies for $40.00 each. After cleaning, polishing, new brakes and >bearings, had>Buchanans true and lace with new 9 gauge stainless steel spokes. Labor and >spokes>were $100.00 per wheel. Think that I could have done it myself with some >patience.>Still, ended up at about $200.00 each when done including tires & tubes. >Think I>would do it over with a Kawasaki front wheel with wider center section and >better>brakes. Keep in mind too, that you can switch rims and centers to match >what you>want, as long as each has the same number of spokes.>Warren>>________________________________________________________________________________
I had the wheel at Sun n Fun . I built it myself from a Yamaha 650 19"wheel. Splitting the casing and insertingthe spacer gave me a 7" widewheel. My appologies to anyone who I promised information to. Work Hasbeen a killer lately. For anyone who wants details, I will send photos anddetails if you will send me addresses. The wheels are on the axel now andI may put the tires on tonight yet. I did my own spoke lacing and all. Ihave about $225 invested including wheels, spokes , new tubes and axel .Dick Navratil________________________________________________________________________________
Re: Pietenpol-List: Fwd: spoked wheels
Subject: spoked wheels-------------------------------1146094082hello group, this is for mike c. or jack phillips or for any one who used buchanans spoke and wheel. i have my hubs turned and drilled and am planning on buying my wheels and spokes from them. my question is. when i call to tellthem what i want to have done do i need to tell them these are for something other than an airplane.seems like i heard something about they would not build them for planes thanks,Robert Bush -------------------------------1146094082hello group, this is for mike c. or jack phillips or f=orany one who used buchanans spoke and wheel. i have my hubs turned anddrilled and am planning on buying my wheels and spokes from them. my questio=nis. when i call to tell them what i want to have done do i need to tell them=these are for something other than an airplane.seems like i heard somethingabout they would not build them forplanes &nbs=p; &n=bsp; = &nbs=p; &n=bsp; thanks,RobertBush = -------------------------------1146094082--________________________________________________________________________________Subject: Re: Pietenpol-List: Fwd: spoked wheels
Original Posted By: RBush96589(at)aol.com
Subject: Pietenpol-List: Fwd: spoked wheelsReturn-path:
Pietenpol-List: RE: spoked wheels
Don, can you enlighten us on your tailwheel design?Chris TracySacramento, Ca________________________________________________________________________________Subject: Pietenpol-List: RE: spoked wheelsDate: Thu, 27 Apr 2006 07:35:40 -0400
I sent this but not sure if it ever showed up on the list...ifso....ignore!Anyway, a copy of my Buchanan's (and the tire company and the go cartbrake) invoices are scanned and stored over on www.mykitplane.com undermy files.Jim Markle ----- Original Message -----
spoked wheels
