Subject: Pietenpol-List: Gary Price doorThe door is 10 inches deep, On the inside of the fus. there is a 1x6xabout 13 or 14 inches making the lower doorway framing. Then you add a1x6 planks to the lower doorway plank. The front plank angles down tothe fwd. landing gear area. The rear plank angles down to the clusterwhere the pilots seat (butt) is. All is held together with 1/8 gussets.If I read the post from the fellow i the wheel chair, he was needing adoor in the rear cockpit for easier entry. I suppose it could be done,but you would need to extend the ply siding past the rear cockpit. Alsoyou are getting into the area where the fus. sides are tapering towardthe tail post. It would be hard, maybe impossible to bend the 1x6planks. Hope my description made sense. I If anyone has questions, bepatient. I'm having rouble with my isp. It has taken me as much as 2 hrsto get on line. Leon S.________________________________________________________________________________
Re: Pietenpol-List: Gary Price door
Original Posted By: jared wilkinson
Subject: Re: Pietenpol-List: Gary Price doorThanks, Leon.Markwrote:Stefan)> > The door is 10 inches deep, On the inside of the fus. there is a 1x6x> about 13 or 14 inches making the lower doorway framing. Then you add a> 1x6 planks to the lower doorway plank. The front plank angles down to> the fwd. landing gear area. The rear plank angles down to the cluster> where the pilots seat (butt) is. All is held together with 1/8 gussets.> If I read the post from the fellow i the wheel chair, he was needing a> door in the rear cockpit for easier entry. I suppose it could be done,> but you would need to extend the ply siding past the rear cockpit. Also> you are getting into the area where the fus. sides are tapering toward> the tail post. It would be hard, maybe impossible to bend the 1x6> planks. Hope my description made sense. I If anyone has questions, be> patient. I'm having rouble with my isp. It has taken me as much as 2 hrs> to get on line. Leon S.> > > > >Visit http://freelane.excite.com/freeisp_____ ... ______Date: Fri, 23 Jun 2000 07:30:09 -0700 (PDT)
