Scott, The notes I made show when viewed from the top of the fuselage,measure at the tailpost; 1/2" and then on the inside side of the longeron, measure 3.6". Connect the two points and this is theamount to cut to make the tailpost longerons come together nicely.It seemed to work for us.However, we glued the tailpost first, put on the gussets top and bottom to help hold it together and then started gluing going forward.Works both ways though, I guess.RodgerPiet in progress ________________________________________________________________________________
