Pietenpol-List: Smoke System
This is for Mike C, and others with exp here,=A0Mike,=A0 Nice smoke job picture on the BPA page!=A0 I have got my pie=t down forupgrades and improvements and would like to add that feature.=A0 Canyou sharewhat you did to get the white stuff?=A0=A0=A0Steve EldredgeSteve(at)byu.eduIT ServicesBrigham Young University=A0________________________________________________________________________________
Pietenpol-List: Re: Smoke System
>> This is for Mike C, and others with exp here,> > Mike, Nice smoke job picture on the BPA page! I have got my piet down for> upgrades and improvements and would like to add that feature. Can you share> what you did to get the white stuff?> Heh, heh, heh. Boy that smoke system is alot of fun. Here is what I did: On one of the rear cylinder exhaust pipesyou weld a fitting about 3" down from the flange. (I used aSwagelok 1/4" female fitting) Drill two small (Number 40 orso) holes into the exhaust pipe inside that fitting you justwelded on. Run 1/4" copper or stainless tubing out from thatfitting about 8" long then connect to rubber hose (to reducevibration and prevent cracking your metal tubing or fiting)The run the hose into some 1/4" poly tubing- the black ortranslucent kind we use to run airspeed lines, etc. I think eventhe hardware stores carry something just like it. Run that poly tubing back to your rear cockpit however you like, and then go to Wal-Mart. In the garden dept. buy a 1/2 gallonbug sprayer/ pressure pump by hand type of deal for about 10 to $15. Unscrew the 'wand' or cut it, leaving some of thevinyl tubing intact. Use your choice of how to connect thebug sprayer outlet to your hose in the cockpit going to thesmoke injection port on your exhaust stack.Call around to local oil distributors and ask if they carryTexaco Canoupus Oil No. 14 I think it is. It used to becalled Corvus Oil. Don't quote me on the No. 14, but I canlook at my 5 gallon container at home to confirm that or not.Ask what's the minimum they'll sell you....usually 5 gallons.IT's not cheap. It's what the airshow boys use. I paid 30$for 5 gallons. (but got quite alot of smoke time with that)Anywho, fill your bug sprayer about 3/4 full, tighten thelid and pump up the pressure. Start your engine and let itwarm up. Run the engine up a little and press the bugsprayer's button to fill your line and start injecting oil intothe hot exhaust stack. Whala, insant IFR. Be careful testing this out- Make sure your fitting isn'tleaking or weld poor. The idea is to keep the oil insideso you don't create a fire hazard. If your holes are toobig you will go thru too much oil too quickly and most ofit will just make your gear and belly oily. In selecting a pump, see if you can try it out at the storefirst- It shouldn't take 100 pumps to get the pressure up- you want one that builds up pressure in fairly short order.I've tinkered with the idea of using a windshield washerpump and a motorcycle battery to pump the oil but just wanted to keep it simple. The bug sprayers don't last super long either with thatoil. If you purge the lines out with air when you are done(ie: turn the sprayer upside down and just pump air thruthe line) they last longer. Lastly, before you go doing this, make you are not inthe non-smoking section on you sectional !Mike C. This is for Mike C,and others with exp here,Mike, Nice smoke job picture on the BPApage! I have got my piet down for upgrades and improvements andwould like to add that feature. Can you share what you did to getthe white stuff?Heh, heh, heh. Boy that smoke system is alot of fun.Here is what I did: On one of the rear cylinder exhaustpipesyou weld a fitting about 3 down from the flange. (I usedaSwagelok 1/4 female fitting) Drill twosmall (Number 40 orso) holes into the exhaust pipe inside that fitting you justwelded on. Run 1/4 copper or stainless tubing out fromthatfitting about 8 long then connect to rubber hose (to reducevibration and prevent cracking your metal tubing or fiting)The run the hose into some 1/4 poly tubing- the black ortranslucent kind we use to run airspeed lines, etc. I thinkeventhe hardware stores carry something just like it. Run that poly tubing back to your rear cockpit however you like, and then go to Wal-Mart. In the garden dept. buy a 1/2 gallonbug sprayer/ pressure pump by hand type of deal for about 10 to $15. Unscrew the 'wand' or cut it, leaving some ofthevinyl tubing intact. Use your choice of how to connect thebug sprayer outlet to your hose in the cockpit going to thesmoke injection port on your exhaust stack.Call around to local oil distributors and ask if they carryTexaco Canoupus Oil No. 14 I think it is. It used to becalled Corvus Oil. Don't quote me on the No. 14, but Icanlook at my 5 gallon container at home to confirm that or not.Ask what's the minimum they'll sell you....usually 5 gallons.IT's not cheap. It's what the airshow boys use. I paid30$for 5 gallons. (but got quite alot of smoke time withthat)Anywho, fill your bug sprayer about 3/4 full, tighten thelid and pump up the pressure. Start your engine and letitwarm up. Run the engine up a little and press the bugsprayer's button to fill your line and start injecting oil intothe hot exhaust stack. Whala, insant IFR. Be careful testing this out- Make sure your fitting isn'tleaking or weld poor. The idea is to keep the oil insideso you don't create a fire hazard. If your holes are toobig you will go thru too much oil too quickly and most ofit will just make your gear and belly oily. In selecting a pump, see if you can try it out at the storefirst- It shouldn't take 100 pumps to get the pressure up- you want one that builds up pressure in fairly short order.I've tinkered with the idea of using a windshield washerpump and a motorcycle battery to pump the oil but just wanted to keep it simple. The bug sprayers don't last super long either with thatoil. If you purge the lines out with air when you are done(ie: turn the sprayer upside down and just pump air thruthe line) they last longer. Lastly, before you go doing this, make you are not inthe non-smoking section on you sectional !Mike C. ________________________________________________________________________________
One last thing- they tell me that the Courvusoil is primarily a vegetable oil used in the food processing industry and dentist drills. I am toldthat this oil produces the BEST smoke you canmake, but have toyed with injecting some Wessonoil or the like.Mike C. ________________________________________________________________________________
Michael D Cuy wrote:> >> Heh, heh, heh. Boy that smoke system is alot of fun.> > Run that poly tubing back to your rear cockpit however you like,> and then go to Wal-Mart. In the garden dept. buy a 1/2 gallon> bug sprayer/ pressure pump by hand type of deal for about> 10 to $15. Unscrew the 'wand' or cut it, leaving some of the> vinyl tubing intact. Use your choice of how to connect the> bug sprayer outlet to your hose in the cockpit going to the> smoke injection port on your exhaust stack.Mike,I have heard that the "Dawn Patrol" guys with their Nieuports useautomotive windshield washer reservoirs and pumps to squirt the oil intothe exhaust stacks. Like the idea of hand pumping/ no electricalbetter, though.Mike List________________________________________________________________________________
Smoke System
Original Posted By: pschultz(at)uplogon.com (Paul Schultz)
Subject: Smoke System Speaking of smoke Michael, I'm having the fitting welded onto myexhaust pipe today, and will try out the gizmo hopefully this evening. I'm using a small pump that's sold through model airplane stores for thesame thing, pumping smoke oil. Those guys tell me that the volumn is tomuch, and they have to restrict the flow, so it may be just the thingfor a full size airplane, plus it uses a 6 volt lantern battery. Robert (hope it works!) Hensarling I fly for FUN. Just happens to be in a piet today. Steve Eldredge Steve- So tell us about your smoke system and the policesomeday...... ok ? I'm waiting for one of the neighbors to call the police onme......but I've given most of them rides so they are all for it. Did you get the correct oil and try that yet ?? Mike C. ________________________________________________________________________________
Subject: Pietenpol-List: Smoke SystemSpeaking of smoke Michael, I'm having thefitting welded onto my exhaust pipe today, and will try out the gizmohopefully this evening. I'm using a small pump that's sold throughmodel airplane stores for the same thing, pumping smoke oil. Thoseguys tell me that the volumn is to much, and they have to restrict theflow, so it may be just the thing for a full size airplane, plus it usesa 6 volt lantern battery. Robert (hope it works!) HensarlingRobert !!Good luck w/ your smoke system...hope you get to try it outtonight. It works best on calm eves so you can make a tight 360 turn and fly into your own trail:) It IS fun!!Mike C. ________________________________________________________________________________
Original Posted By: robert hensarling
>>> I fly for FUN. Just happens to be in a piet today.> > Steve EldredgeSteve- So tell us about your smoke system and the police someday......ok ? I'm waiting for one of the neighbors to call the police on me......butI've given most of them rides so they are all for it. Did you get the correct oil and try that yet ??Mike C.I fly for FUN. Justhappens to be in a piet today.Steve EldredgeSteve- So tell us about your smoke system and the policesomeday......ok ? I'm waiting for one of the neighbors to call the policeon me......butI've given most of them rides so they are all for it. Did you get the correct oil and try that yet ??Mike C.________________________________________________________________________________
-----Original Message-----
Original Posted By:>> Michael D Cuy
Original Posted By:> Michael D Cuy
Another pump that's quite usable and very cheap is a washer fluid motoravailable from most auto parts stores. I used one for years for pumpingglow fuel into and out of model planes. Works great.KenOn Thu, 27 May 1999, robert hensarling wrote:> > -----Original Message-----
Subject: Pietenpol-List: Smoke SystemMichael, Would it be possible to get drawings of your smoke system? I'd like to incorporate it in my plane. I can send a SASE, or whatever. Thanx, in advance, Don Cooley________________________________________________________________________________
Re: Pietenpol-List: Jury Struts
That's close . . . the 220 placard is against a harmonic, but you cannotfeel it (i.e. the placard) There are several other airplanes with similarrestrictions for the same reason, the Grumman Tiger for example.________________________________________________________________________________Date: Wed, 23 Aug 2000 08:43:41 -0400
Re: Pietenpol-List: Varnish:
Subject: Re: Pietenpol-List: Varnish:Mike,Did you varnish your ribs before assembling the wing? Tom________________________________________________________________________________Date: Wed, 23 Aug 2000 09:59:36 -0400
Re: Pietenpol-List: Smoke System
Subject: Re: Pietenpol-List: Smoke SystemIn a message dated 8/23/2000 9:06:21 AM Central Daylight Time, Michael.D.Cuy(at)lerc.nasa.gov writes:>thanks Mike ... great job explaining setup ... I would think "smoke" was a necessity in a Nie (your message is printed & in file)Thanks againJohn D________________________________________________________________________________Date: Wed, 23 Aug 2000 10:47:17 -0400
Subject: Re: Pietenpol-List: Smoke SystemIn a message dated 08/23/2000 9:06:21 AM Central Daylight Time, Michael.D.Cuy(at)lerc.nasa.gov writes:I've never sketched the system out but can describe it here and I'd bet you'd have no trouble in duplicating i >>Thanks Mike for the detailed description of your smoke system...this time I made a copy and I'll wager many others did too !! Thing I'll try it on the Model A. Hope the short stacks will provide the heat required. Don Hicks ________________________________________________________________________________
Original Posted By: "ED GRENTZER"
Subject: Re: Pietenpol-List: Smoke SystemIn a message dated 8/23/00 10:28:39 AM Central Daylight Time, DonanClara(at)aol.com writes:>My thoughts exactly !! I think I'll try it on the rear stack, but make the stack 3 or 4 inches longer than the other three. If it don't work, it should make for an interesting conversation piece..."Yeah, I had to add 82 grams of weight, at that paticular arm, to make my CG come out right". :)Chuck G.________________________________________________________________________________
I'll be interested to see, but I'll bet money that a Model A stack, evenlengthened, is too short to produce proper smoke. More likely you'll coveryour airplane (and yourself) in half burned oil. Good luck, though. (takea fire extinguisher!)________________________________________________________________________________
Subject: Re: Pietenpol-List: Smoke System Well guys, I think my parade has been thoroughly soaked. Fact is,you're probably right !! Now I'll add the fire extinguisher to my test stand. Thanx to all for the input Don H.________________________________________________________________________________
Original Posted By: Chris A Tracy
Subject: RE: Pietenpol-List: PicturesI could be mistaken but the Piet in the pic looks like the weedon/davisPiet out of Brodhead. Which now has a model "A" on it.If its the oneI'm thinking of ,its actually dark green and orange. The engine is aleblond 65 or 75 . They couldn't keep valves in it so switched to theFord. Lowell Frank mounted a 145 warner scarab on his short Piet lastwinter. it weighs 38pounds more than the ford. and he didn't change anything for the weightand balance. It is mounted closer to the fire wall and that might makethe difference. He said the trim is very throttle sensitive. 60% powergives him around 85mph. But requries some forward stick. You should seeit climb.Ted T________________________________________________________________________________Date: Thu, 24 Aug 2000 17:13:11 -0700Subject: Re: Pietenpol-List: Smoke System
Subject: Pietenpol-List: Smoke SystemThis smoke system seems like a lot of fun. How does it work? Is it easy to build and fit one? Or do you just buy one to bolt on?regards TugTug,My smoke system consists of an after-market windshield washer pump and tank, plumbing to each exhaust pipe, and wiring to the switch on the power lever. Iisolated / mounted the tank on the upper left motor mount tubing, with a couple layers of rubber strap. I routed the clear tubing to a Tee fitting securedin rubber, to the engine mount, then used 1/8" brass tubing to each of the fittings in the exhaust pipes. I laid out the route of the tubing, marked thepipes, and removed both exhaust pipes. I cut a 1/8" pipe coupler in half, radiused each half to the radius of the pipe, and oxy / accy welded them to theaft pipe of each side. After welded, I drilled one #60 hole through the exhaustpipes. I placed these holes toward the bottom edge of the fittings, theorizing that if oil would lay in there it would gum up. The switch is a pushon / push off button, that is mounted right to the throttle handle. This location allows me to work the smoke without taking my hand off the throttle. I originally thought it would only smoke good at full power, but came to find I don'tneed much over 1/4 throttle to Smoke 'Em Up !! I can smoke 'em while taxiing,without any problem !! My exhaust pipes point down and away from the fuselage, and even when all the oil doesn't vaporize, the fuselage hardly getsanything on it.I have a couple of squawks on the system, that I have taken care of. 1.) I mounted the tank at about the same level as the fittings on the exhaust pipes, and it always dribbles out the pipes, with a little bit of smokeas a result. Over a period of a couple of hours, it will drain the tank, but I usually 'Smoke em up' before that happens.2.) When I ran the tank empty, and refill it, the pump would cavitate because of the way the line ran from the bottom of the tank to the pump, and Iwould always have to prime the pump, by blowing in the top of the tank. I gotsome strange looks from folks, while I performed this operation !!3.) The tank was too small. It only was big enough to do about 3 smoke runs. I would like to put about a 5 gallon bucket up there on the firewall, butI don't have enough room !!4.) I had to remove the top cowling to re-fill the tank.I'm building a new tank out of fiberglass / West System resin, with a fill tube out to the right side of the cowling. I'll mount it lower on the firewall. This will take care of all the squawks.5.) I now have been using the new smoke tank, but I have a small leak in the tank. I used West Systems resin for the fiberglass tank, and evidently I didn't get the seam sealed up good enough. I've never had that problem when Iused polyester resin, but it kicks very quickly. The West System gives some time, but it is also quite a bit more expensive. After the warnings about thestuff catching on fire, I'll be repairing the tank before my next flight.Chuck G.________________________________________________________________________________
>> Smoke System
>> Subject: Smoke System>> >> Speaking of smoke Michael, I'm having the fitting welded onto my exhaust>> pipe today, and will try out the gizmo hopefully this evening. I'm using a>> small pump that's sold through model airplane stores for the same thing,>> pumping smoke oil. Those guys tell me that the volumn is to much, and they>> have to restrict the flow, so it may be just the thing for a full size>> airplane, plus it uses a 6 volt lantern battery. >> Robert (hope it works!) Hensarling>Robert !!Good luck w/ your smoke system...hope you get to try it out tonight. It worksbest on calm eves so you can make a tight 360 turn and fly into your own trail:) It IS fun !!Mike C. -----Original________________________________________________________________________________
> Smoke System
Original Posted By: Borodent(at)aol.com
> Subject: Smoke System> > Speaking of smoke Michael, I'm having the fitting welded onto my> exhaust pipe today, and will try out the gizmo hopefully this evening. > I'm using a small pump that's sold through model airplane stores for the> same thing, pumping smoke oil. Those guys tell me that the volumn is to> much, and they have to restrict the flow, so it may be just the thing> for a full size airplane, plus it uses a 6 volt lantern battery. > Robert (hope it works!) Hensarling> > > > I fly for FUN. Just happens to be in a piet today.> > Steve Eldredge> > Steve- So tell us about your smoke system and the police someday......> ok ? I'm waiting for one of the neighbors to call the police on me......but> I've given most of them rides so they are all for it. > Did you get the correct oil and try that yet ??> > Mike C.> > ________________________________________________________________________________
