Original Posted By: "Greg Yotz"
The plans show attaching the horz stab to the fuse with screws.Has anyone used this method or would AN bolts be the way to go?CarlSign up with Paypal,it's free and they willgive you $5.00 just for joining.https://secure.paypal.x.com/refer/pal=s ... gsinet.net ________________________________________________________________________________
Pietenpol-List: stab attachment
Re: Pietenpol-List: Lycoming Engine
Which engine is it exactly?? I have a O-145-B2 Lycoming that I'm adapting.I've got the long fuse.Greg________________________________________________________________________________Date: Fri, 15 Sep 2000 15:45:21 -0400
Re: Pietenpol-List: stab attachment
Original Posted By: Jay
Re: Pietenpol-List: Lycoming Q & A
I'm going over to work on the plane in the morning. I've printed your postout and I'll try to answer your questions.The ones I know now are:The going price is what ever someone is willing to pay... I figured it isworth $1000-$1500 with good compression and no logs.(mine too)I don't have a manual yet. I found a guy who did and sent a check buthaven't seen it yet. I've never seen a starter or alternator on one butI've had several 'old hands' tell me 'they made them but who would want theweight?' I'm going to hand start....I'm just about done with a mount patterned off a Cub mount. The Cub mountmight work but I didn't have access to one that wasn't on an airplane totry... Also patterning the engine cowl after a Cub...Greg>> Hi, Greg.>> In answer to your earlier e-mail, that's the same> Lycoming as what I'm getting; an 0-145-B2. If you> don't mind, let me ask you a couple of questions> about it. What type carb does it use? (Mine is> missing) Also, does it use the same magneto harness> as a Bendix S-20 magneto? (Mine are cut to pieces)> What is a fair price to pay for one with decent> compression, but no logs? Do you have a manual for> this motor, by chance? Also, have you ever seen an> electric starter and/or alternator setup for one of> these? Also, do you think I can adapt the original> Cub motor mount that came with it, or do I have to> try and build one from scratch for my short fuselage> Piet? Thanks for your help on this.>> Jay Travis>________________________________________________________________________________
Re: Pietenpol-List: fuselage longerons
Javier, I bought my longerons from Wicks, they shipped to me by truck freight.They are set up to handle these sorts of orders, give them a call and they can help you out. If you do this it helps to have a business address to ship to, it's cheaper that way. They crated it very securely. I'm sure Aircraft Spruce can do that too. I agree with John Langston, I wouldn't splice my original longerons. I'd like to start out with full length pieces. I don't mind splicing in as a repair, I just wouldn't start out that way.Good Luck,Gary Meadows________________________________________________________________________________
Subject: Re: Pietenpol-List: stab attachmentIn a message dated 9/15/00 12:14:45 PM Pacific Daylight Time, skycarl(at)megsinet.net writes:>Screws would probably work, but AN-3 bolts are much more comforting to me. The aircraft in the museum at Oshkosh have hardware store bolts.________________________________________________________________________________Date: Sat, 16 Sep 2000 15:42:05 -0500Subject: Re: Pietenpol-List: stab attachment
Subject: Re: Pietenpol-List: stab attachmentIn a message dated 9/16/00 1:48:40 PM Pacific Daylight Time, nle97(at)juno.com writes:>I used AN-3 bolts and nylon locking nuts on all of mine. The Bolts were long enough to pass thru the the horizontal and longerons with a 3/16 large area washer and nut as stated. I just didn't like the idea of nutplates holding primary structure together. ________________________________________________________________________________
"Richard Navratil" Not to make you repeat all the past discussion. About what date was that.I'll look it up in archives. I'm at this same point too.Dick Navratil----- Original Message -----
