Pietenpol-List: Tailpost construction
Ok guys-- my first fusilage side is in the jig- all of my struts and braces are cut and fitted, I know I can come up with a way to fit the tailpost which will work, but there must be a proper way to do it. You obviously don't put a 1"X 1" tailpost in each side and then rip them both down the middle when you pull the posts together,or do you ?, So my question is:Do you put a 1/2X 1" in each fusilage side and glue them together when you pull the tail together or do you leave the tailpost out until after the sides are pulled together and then fit it in, and if the later is the case should you put the gussets on before you pull it together. It seems like it would be hard to get perfect alignment with out something solid holding the upper and lower longerons in alignment???????? Everything I've read says simply to pull the fusilage sides together and carefully fitt them together. If someone could let me know how they did this or how it is normally done I would appreciate it much. Ed G. Piet in Progress Palm Harbor Florida________________________________________________________________________________
Re: Pietenpol-List: Tailpost construction
Original Posted By: "Conoly"
Subject: Re: Pietenpol-List: Tailpost constructionIn a message dated 9/11/00 5:29:01 PM Pacific Daylight Time, flyboy_120(at)hotmail.com writes:>Yes, put in a 1x1 tail post into each side, then pull sides together, layout a cut line (approx 7 degrees) and cut (by hand) for a net width of 1" when glued- It,s easy! ________________________________________________________________________________
Thanks Doug Thats the way the plans made it look, but it seemed odd to put in two1"X1"s and then rip them both down to 1/2" X 1"s but I guess thats the only way to get the angle to fit right. Ed G.>From: Doug413(at)aol.com>Reply-To: pietenpol-list(at)matronics.com, Doug413(at)aol.com>To: pietenpol-list(at)matronics.com, flyboy_120(at)hotmail.com>Subject: Re: Pietenpol-List: Tailpost construction>Date: Mon, 11 Sep 2000 23:00:09 EDT>>>In a message dated 9/11/00 5:29:01 PM Pacific Daylight Time,>flyboy_120(at)hotmail.com writes:>> braces are cut and fitted, I know I can come up with a way to fit the> tailpost which will work, but there must be a proper way to do it. You> obviously don't put a 1"X 1" tailpost in each side and then rip them both> down the middle when you pull the posts together,or do you ?, So my >question> is:> Do you put a 1/2X 1" in each fusilage side and glue them together when >you> pull the tail together or do you leave the tailpost out until after the> sides are pulled together and then fit it in, and if the later is the >case> should you put the gussets on before you pull it together. It seems like >it> would be hard to get perfect alignment with out something solid holding >the> upper and lower longerons in alignment???????? Everything I've read says> simply to pull the fusilage sides together and carefully fitt them >together.> If someone could let me know how they did this or how it is normally done >I> would appreciate it much.> >>>Yes, put in a 1x1 tail post into each side, then pull sides together, >layout>a cut line (approx 7 degrees) and cut (by hand) for a net width of 1" when>glued- It,s easy!>>________________________________________________________________________________Date: Tue, 12 Sep 2000 05:11:33 -0700 (PDT)
RE: Pietenpol-List: Tailpost construction
Just to provide a different approach, I pulled the sides together and thenput in the *single* 1x1 tailpost. There is a missing bevel of wood near thefront edge of the tailpost, but not much. Gussets went on after.steve e.-----Original Message-----
I also put the sides together first and then put in the tailpost. It workedfineand is more than strong enough. That was a brow sweater getting the twosidesaligned and straight. I used a string and measured and checked by that, butifyou look back at the archives,, someone mentioned running plumbobs to keepalignment.That idea might be good for you.Carl-----Original Message-----
"Michael Brusilow" >>Just to provide a different approach, I pulled the sides together and then>put in the *single* 1x1 tailpost. There is a missing bevel of wood nearthe>front edge of the tailpost, but not much. Gussets went on after.>>steve e.That's how I did it.Mike B Piet N687MB ( Mr Sam )________________________________________________________________________________
Subject: Re: Pietenpol-List: Tailpost constructionIn a message dated 9/12/00 4:24:35 AM Pacific Daylight Time, flyboy_120(at)hotmail.com writes:>They are not a true 1/2 x1 because they taper. Just make sure the total width of the aft edge of the tailpost including the 1/8 gusset plate on each side is 1 inch. There is a reason for that and you will see it when you install the tail surfaces and brackets.________________________________________________________________________________
Original Posted By: "Domenico Bellissimo"
"Michael Brusilow" >>I also put the sides together first and then put in the tailpost. It worked>fine>and is more than strong enough. That was a brow sweater getting the two>sides>aligned and straight. I used a string and measured and checked by that, but>if>you look back at the archives,, someone mentioned running plumbobs to keep>alignment.>That idea might be good for you.>CarlThe plumb bob was my suggestion.Strike two center lines. One on the work table & a center line over thetable done with wire running below the ceiling. I fixed each end of the wireto opposite walls with turnbucles to provide tension. The wire is locatedtrue with the center line on the table. To do this, suspend plumb bobs ( 4 )from the wire to line up with the table center line. The plumb bobs aremovable in the horozontal & verticle planes. The plumb bob strings come fromthe wire through key rings. Thus , they can be moved fore & aft & up & down.As you can see,by this method, one can true up the firewall to the tailpost,the center section, or any station on the airplane.Mike B Piet N687MB ( Mr Sam )________________________________________________________________________________
While everyone is on the subject of tailposts... Has anyone attached theitshoulder harnesses back to the tailpost?Seems like this should give the most strength.Greg>> >> > They [the tailposts] are not a true 1/2 x1 because they taper. Justmake sure> > the total width of the aft edge of the tailpost including the 1/8 gussetplate> > on each> > side is 1 inch. There is a reason for that and you will see it when you> > install the tail surfaces and brackets.>> OK, Doug, I see that the fittings on either side of the vertical fin areonly 1"> apart (the thickness of the spar). The drawing, though, shows thetailpost being> 1" wide at the trailing edge and it appears that this does not includingthe> gussets. If the thickness of the gussets keeps the fittings from liningup, what> about the fact that the tailpost tapers and no matter how you work it, thelower> fittings are going to be more than 1" apart because they are not at thevery> trailing edge of the tailpost?>>________________________________________________________________________________
"walter evans" This is one of those custom fit areas. I had gone ahead and made all of thebrackets for that area ahead of time. Scrap metal time.It turned out to be easy. Keep the aft/ lower brackets per the print. theaft / upper brackets, leave the verticle part per print, but leave thehorizontal piece long( to be cut later) and undrilled.now1.mount the aft/lower bkts2.drill up through the horz. stab. wood3. doing so you "spot" the undrilled upper bracket4. remove upper bkt. and finish drill.5. shape the end of the bracket to look good"This way it doesn't matter how wide the tailpost is. "To shoot the horz stab for being square and even, I put an aircraft nail inthe top of the turtledeck, behind the rear seat. and had a measuring wireor tape ( string stretches too much) hooked to the nail. This way it waseasy to swing back and forth to get the rear tips of the horz stab exact,before drilling to the fuse.walt-----------------------------------------------------Click here for Free Video!!http://www.gohip.com/freevideo/----- Original Message -----
Original Posted By: Greg Yotz
Concerning your query; Yes, thats the way I did it.Put a triangular 1" thick filler block, I think I used white ash,sandwiched between two 1/8" ply gussets then bolted a 12 ga 4130 strap tothat and atttached the cable shackle to that. Used 1/8 cable to theshoulder harness fitting. This is between the top longerons. This gives agood cable angle and the strongest anchor point.----- Original Message -----
Original Posted By: Jim Sury
Thanks Lou. That is basically what I'm trying to do also. I just wanted asanity check.GregLou Wrote:> Concerning your query; Yes, thats the way I did it.>> Put a triangular 1" thick filler block, I think I used white ash,> sandwiched between two 1/8" ply gussets then bolted a 12 ga 4130 strap to> that and atttached the cable shackle to that. Used 1/8 cable to the> shoulder harness fitting. This is between the top longerons. This givesa> good cable angle and the strongest anchor point.>________________________________________________________________________________Date: Tue, 19 Sep 2000 09:45:09 -0500
Original Posted By: javier cruz
Subject: Re: Pietenpol-List: Tailpost constructionIn a message dated 9/18/00 1:03:06 PM Pacific Daylight Time, rambog(at)erols.com writes:>True, leave some excess on the fittings and trim after all is fit.________________________________________________________________________________Date: Tue, 19 Sep 2000 21:12:02 -0700 (PDT)
