I just got the word from the motorcycle guy.He says that my hubs, spoke holes drilled stright thru,, (but offset between flanges) can only be laced as double cross pattern.Question, Is a double cross pattern strong enough for a/c use using 9, or 8 gauge spokes ?Bob________________________________________________________________________________
Pietenpol-List: spoke wheels lacing
Re: Pietenpol-List: spoke wheels lacing
Original Posted By: Tony Weeks
Subject: Re: Pietenpol-List: Leading EdgeIn a message dated 10/11/00 8:35:48 PM Central Daylight Time, Isablcorky(at)aol.com writes:>No filler is needed between the ribs, under the aft edge of the 1/16" plywood. When the fabric is shrunk down, it pulls the aft edge of the plywood down tight, very nicely. Chuck Gantzer________________________________________________________________________________Date: Wed, 11 Oct 2000 23:12:53 -0700Subject: Re: Pietenpol-List: spoke wheels lacing
RE: Pietenpol-List: Leading Edge
This is the way I did it on my plane too. I would only add that if I wereto do it again, I would add a bridge strip between the root rib and the onenext to it. My fabric over the past two years has pulled the rib toward thetip slightly causing a slight pucker. Adding a spar cap would prevent this.Stevee-----Original Message-----
