Can someone please confirm that two extra ribs are needed (total of 30)to build the 3-piece wing? In doing the nose and tail ribs, do yougenerally make whole ribs and cut out the middle, or just build the noseand tail sections in the jig?Richard________________________________________________________________________________
Pietenpol-List: center section ribs
Re: Pietenpol-List: center section ribs
Richard, Yep, you found out like I did about those extra 2 ribs!! I thought I was done! The joint where you bolt the wing panels to the center section require a sheeted rib on the wing panel and the center section, so they'll only be separated by a couple of inches, but you need those end caps to stretch fabric to. On the partial ribs, I'm going to build the rib-let a little longer than what I need to make sure I get a good contour, but I'm not going to build entire rib and then cut them up - that's just too traumatic!Gary MeadowsSpring, TX________________________________________________________________________________Subject: Re: Pietenpol-List: center section ribs
owner-pietenpol-list-server@mat Re: Pietenpol-List:
10:24:18 AMThis would seem like a good place to simply do a plywood cut out for arib or partial rib.Mike "Gary Meadows" To: pietenpol-list(at)matronics.com Sent by: cc: owner-pietenpol-list-server@mat Subject: Re: Pietenpol-List:center section ribs ronics.com 11/21/2000 10:02 AM Please respond to pietenpol-list Richard, Yep, you found out like I did about those extra 2 ribs!! I thought Iwasdone! The joint where you bolt the wing panels to the center sectionrequirea sheeted rib on the wing panel and the center section, so they'llonly beseparated by a couple of inches, but you need those end caps tostretchfabric to. On the partial ribs, I'm going to build the rib-let a little longerthanwhat I need to make sure I get a good contour, but I'm not going tobuildentire rib and then cut them up - that's just too traumatic!Gary MeadowsSpring, TX________________________________________________________________________________Date: Tue, 21 Nov 2000 10:24:49 -0500
> Re: Pietenpol-List: Aircamper.org Supplier List
Original Posted By: "David Boyd"
I bought metal fittings for the center section of the 3-piece wing. Very nice stuff. Not cheap however.>From: Doug413(at)aol.com>Reply-To: pietenpol-list(at)matronics.com>To: pietenpol-list(at)matronics.com>Subject: Re: Pietenpol-List: Aircamper.org Supplier List>Date: Wed, 15 Nov 2000 21:02:34 EST>>>In a message dated 11/15/00 10:18:17 AM Pacific Standard Time,>artsfoto(at)yahoo.com writes:>>> > What specifically do Orrin Hoopman and Doug Bryant> > supply? I'm familiar with the other companies. Also,> > anyone bought components from Replicraft?> >> > Ed> >> >> >>>Ed,>>I was supplying some of the steel parts i.e. control stick assy, elevator>bellcrank, front rudder pedals, rudder bar assy, engine mount plates....>But I just became too busy and wanted to build some more complete airplanes>myself or with partners here in Wichita. Vi Kapler is now building more>parts in addition to the items he was already making i.e. alum hinges,>corvair stuff, great stuff. His parts are excellent. I think Orrin used >to>supply the early version drawings and some other things which BHP had>designed and tested like a steerable tail skid...>>Doug Bryant Wichita, Ks>>________________________________________________________________________________
Original Posted By: "Ron Butcher"
Forgot to say I bought from Replicraft.>From: Doug413(at)aol.com>Reply-To: pietenpol-list(at)matronics.com>To: pietenpol-list(at)matronics.com>Subject: Re: Pietenpol-List: Aircamper.org Supplier List>Date: Wed, 15 Nov 2000 21:02:34 EST>>>In a message dated 11/15/00 10:18:17 AM Pacific Standard Time,>artsfoto(at)yahoo.com writes:>>> > What specifically do Orrin Hoopman and Doug Bryant> > supply? I'm familiar with the other companies. Also,> > anyone bought components from Replicraft?> >> > Ed> >> >> >>>Ed,>>I was supplying some of the steel parts i.e. control stick assy, elevator>bellcrank, front rudder pedals, rudder bar assy, engine mount plates....>But I just became too busy and wanted to build some more complete airplanes>myself or with partners here in Wichita. Vi Kapler is now building more>parts in addition to the items he was already making i.e. alum hinges,>corvair stuff, great stuff. His parts are excellent. I think Orrin used >to>supply the early version drawings and some other things which BHP had>designed and tested like a steerable tail skid...>>Doug Bryant Wichita, Ks>>________________________________________________________________________________
