Pietenpol-List: Weight and Balance Spreadsheet
Ron, et al,Back in the Feb '00 issue of Kitplanes there was an article on calculatingweight and balance. Basicly you just go to http://www.kitplanes.com ,download the information and it will take out a lot of the computationalheadaches from the operation.RodgerPiet in progress________________________________________________________________________________
Re: Pietenpol-List: Weight and Balance Spreadsheet
Original Posted By: david kowell
Ok Piet List,To check out the Kitplanes website concerning the W&B, here is whatI can discern: I received the following reply from Kitplanes when I wasunable to find the information on W&B. And sure enough, when Ifollowed it, there it was. HOWEVER, the Kitplanes website "stuff" tookup all but 2x3" of the screen, and there it was in all it's glory on the2x3"area of the screen. "Gee thanks" was my response to myself. But maybeit is due to the fact that I don't know much about computers, but I wasnever able to make the info full screen. So I turned the computer off andwent down to the basement and worked on the Piet. I gave up on that2x3" screen of data and when W&B times comes along, will do it the oldfashion way.Following is the Kitplanes response to where the data is:"Since the publication of that article, the KITPLANES website hasbeen completely redesigned. Click on the tab "FEATURES" and go tothe top of the left column on that page. You will find a referenceto supplemental material and a link to click on. That will takeyou to a list of the materials available and the weight and balancecalculations is in the list.If you have any further problems, please don't hesitate to contactme.Julia DownieData Manager, KITPLANES"----- Original Message -----
RE: Pietenpol-List: Weight and Balance Spreadsheet
Rodger,,, I might have sent the wrong file. The file I sent I believe was a.doc....I'm sending you the excel file from the kitplane site. I tried it and itworks prettygood. I had to estimate the numbers as my planes not done yet.Here it is,,,Carl-----Original Message-----
