Pietenpol-List: Part I of my new article for the NL
Re: Pietenpol-List: Part I of my new article for the NL
Original Posted By: kgardner(at)odu.edu
I just went through that with the turtle deck stringers. they are 1/4" X 1".The dimension is not on the plans but it is in the Flying & Glider manual. Ed G.>From: "Mckellars" >Reply-To: pietenpol-list(at)matronics.com>To: >Subject: Pietenpol-List: stringers>Date: Mon, 26 Feb 2001 14:22:03 -0600>>>Kip, I cant find the size of the stringers on my plans. What size did>you use? Thanks Mark>>________________________________________________________________________________Subject: Re: Pietenpol-List: Part I of my new article for the NL
02/26/2001 04:44:14 PMChris,I can't really contribute much to the whole discussion of old wiretechnology, except to add one point. Many years ago my best friend ran apiano repair business, and I spent my late teenage years hanging out in hisshop learning the trade. Piano wire is softer and more flexible than the'music wire' stuff sold in hobby shops. It comes on rolls & we used a LOTof it to restring one piano! Obviously, though, it has a pretty hightensile strength, or it wouldn't withstand the loads put on it in a piano.I've been out of that business for a long time, but there are several ofwholesale piano repair supply houses still around if someone wanted to dosome research & experimenting.Cheers!Kip GardnerLaboratory Manager, ODUDept. of Ocean, Earth & Atmospheric Sciences4600 Elkhorn AvenueNorfolk, VA 23529(757)683-5654Bumper Sticker of the Week:"Don't Drink and Park - 'Accidents' Cause People"________________________________________________________________________________Date: Mon, 26 Feb 2001 17:29:15 -0500
Subject: Re: Pietenpol-List: Part I of my new article for the NLHaving been in the Piano business for over forty-five years I have a lot of old spools of wire unusable for piano stringing because of surface rust. State your case and I will furnish free of charge all the wire you need.Corky in La where piano wire rusts.________________________________________________________________________________
Subject: Re: Pietenpol-List: Part I of my new article for the NLIn a message dated 2/26/01 4:37:39 PM Pacific Standard Time, Isablcorky(at)aol.com writes:> Having been in the Piano business for over forty-five years I have a lot of > old spools of wire unusable for piano stringing because of surface rust. > State your case and I will furnish free of charge all the wire you need.> Corky in La where piano wire rusts.> > > I was in on some of this discussion earlier. I would be sure that the wire is obtainable in the lengths needed, but it's the ferrules which would not be readily found or made by an individual. The Kansas Aviation Museum here in Wichita is building a 1923 Laird Swallow and they had some ferrules made somewhere here and donated, but because the Swallow is not going to be airworthy I'm not sure if the ferrules are heat treated. Guess I could ask them Doug Bryant________________________________________________________________________________Date: Mon, 26 Feb 2001 21:06:04 -0500
Subject: Re: Pietenpol-List: Part I of my new article for the NLIn a message dated 2/26/01 6:01:47 PM Pacific Standard Time, BOBKA(at)compuserve.com writes:> doug,> > Is that what how they would be manufactured? Wind them in the annealed> condition and then heat treat?> > Yes, that is why it would be difficult for an individual to guaranty proper heat treat and temper. Doug Bryant________________________________________________________________________________
Re: Pietenpol-List: Joystick Connecting Link
Original Posted By: javier cruz
Subject: Re: Pietenpol-List: Joystick Connecting LinkIn a message dated 2/26/01 6:23:37 PM Pacific Standard Time, jackphillips(at)earthlink.net writes:> Maybe I'm overly cautious, but it seems raising the link a half inch and > using the next gage of tubing is a prudent design change. Any thougths > out there?> > Jack Phillips> > > Jack,I appreciate your analysis on the tube. I suppose 1/2 inch higher and heavier wall would be all right, but this would further irritate the interference you mentioned. I have built six sets of controls and have about 90 hours on my first piet ('A' powered) and haven't experienced any kind of heavy control forces during G loading. I've had it in some rough air, but don't do any abrupt maneuvers. In fact, A pinkie is all that's needed on mine. It is very very easy to land; it behaves so well. I did not have the clearance problem you mentioned hitting the rudder bar or the rudder bar stand, but it does lightly hit the cutout in the front seat bulkhead on full left aileron, but I haven't needed nearly that much so far. I had an engineer fiend help me design my lift struts so I wouldn't have to use jury struts. Doug Bryant ________________________________________________________________________________Date: Mon, 26 Feb 2001 20:23:18 -0800 (PST)
A suggestion;Two methods to attach the stringers to the formers:1) notch the formers or: 2) no sweat method, lay the stringers on the formers, line them up,thennotch individual pieces of ply, notch them, set them on the stringers, &glue them to the formers.Mike B Piet N687MB ( Mr Sam )________________________________________________________________________________Date: Tue, 27 Feb 2001 12:16:36 -0600Subject: Re: Pietenpol-List: Part I of my new article for the NL
RE: Pietenpol-List: Part I of my new article for the NL
Ian Holland sent me the article on ferrules that was in the BPA letter in93. I can put that on my website with the other piet stuff so any one caneither read it from there or copy it. I have to thin it out a bit as the wayI have it now it is rather large. ( Trying to save on space so I can post asmuch as possible.) Give me a bit and I will have it up with the weight andbalance and rib tool and other stuff. I'll post when it's ready online.PS.... Got my spars together finally. Glad I'm over that hurdle. Now I justhave to finish the ribs.CarlPlease visit my website atwww.megsinet.net/skycarl-----Original Message-----
RE: Pietenpol-List: Joystick Connecting Link
Remove the front stick.Just a little tongue in cheek.Steve E.-----Original Message-----
Subject: Re: Pietenpol-List: Part I of my new article for the NLIn a message dated 2/27/01 4:53:00 PM Pacific Standard Time, BOBKA(at)compuserve.com writes:> If you look at an unsquashed nicopress fitting, this is about what it> should look like. It should have very little slop around the bracing wire.> > Chris Bobka> Tech Counselor> > > Gents ,I called the Kansas Aviation Museum today and they did have some ferrules made per the vintage spec for the Laird Swallow. They were made by the Kansas Coil Spring company and cost 2$ ea. They also told of a person who winds them from 3/32 or 1/8 4130 welding rod, sqwishes them and then heats cherry red and quenches in oil (not sure what he does for the temper). I am going to make a couple of these and take them to Raytheon (where I work) and test them. I can wind the coils on my lathe in back gear. I have a copy of the spec. I wouldn't trust anything like this unless I was confident that it met its design criteria. The first and only ride I had in a piet until I built my own, had hard wire on the tail. Doug Bryant________________________________________________________________________________
Subject: Re: Pietenpol-List: Part I of my new article for the NLIn a message dated 2/27/01 9:36:07 PM Pacific Standard Time, BOBKA(at)compuserve.com writes:> I have the Curtiss drawing if you want I can mail it to you. SAE aviation> Yes ,Doug Bryant720 N SandpiperWichita Ks 67230________________________________________________________________________________
Original Posted By: "Rodger & Betty Childs"
Subject: Re: Pietenpol-List: Part I of my new article for the NLIn a message dated 2/27/01 9:38:57 PM Pacific Standard Time, BOBKA(at)compuserve.com writes:> Ok! Give me your address. Doug Bryant ________________________________________________________________________________
Subject: Re: Pietenpol-List: Part I of my new article for the NLIn a message dated 3/3/01 7:41:33 AM Pacific Standard Time, BOBKA(at)compuserve.com writes:> Greg Cardinal and I are putting together a package of stuff relating to the> aircraft wire and ferrules. You should have it by next friday.> > Excellent! Thanks Doug Bryant________________________________________________________________________________Date: Sat, 3 Mar 2001 21:13:21 -0500
