Pietenpol-List: Re: BPA Newsletter Reprints
After nearly a year of studying plans, moving house,studying plans, building workshop, studying plans........I have finally made a start.Thought I had better start with a couple of the smaller parts,so have made up the tail fin and rudder and have bought a set of Vi Kaplers alloy hinges to fit.The problem is, having measured the bolt holes I find they appear to be 4mm or 5/32" diameter.Can anyone tell me where to buy suitable bolts for these hinges, (preferably AN)RodWestern Australia________________________________________________________________________________Subject: Pietenpol-List: Re: BPA Newsletter Reprints
04/19/2001 07:34:41 AMFor all who sent me checks for Newsletter reprints:Thanks to all for the patience. I mailed all the reprints on Monday.I made a mistake in counting the pages and undercounted. I made upfor it by sending everything bookrate instead of priority mail. So, Iguess you shouldn't start looking to your mailboxes for a week or so.I made an exception with copies to Alaska and Quebec which wentairmail.I'm still waiting on checks for a couple of copies and I haven'tgotten the EAA copy off yet, but that just about wraps it up.Mike BellPietenpol under construction in the Gaston Airplane Factory (one sideof my garage)Gaston, SC________________________________________________________________________________
Re: Pietenpol-List: Rudder hinge bolts
Subject: Re: Pietenpol-List: Rudder hinge boltsIn a message dated 4/18/01 11:35:24 PM Pacific Daylight Time, rodwooller(at)hotmail.com writes:> After nearly a year of studying plans, moving house,studying plans, building> workshop, studying plans........I have finally made a start.> Thought I had better start with a couple of the smaller parts,so have made > up the tail fin and rudder and have bought a set of Vi Kaplers alloy hinges > to fit.> The problem is, having measured the bolt holes I find they appear to be 4mm > or 5/32" diameter.> Can anyone tell me where to buy suitable bolts for these hinges, > (preferably > AN)> > Rod> Western Australia> > > Rod,The plans call for 8-32 machine screws and the aluminum hinges from Vi Kapler are countersunk so they screw need to be flat head. The dia of this size screw is .164". No need for them to be AN. Hardware store machine screws are fine. Aircraft Spruce is a good souce for these screws in AN as you asked. Do you have a Spruce catalog? I Have a bunch of these screws in non AN which is what I use on all my planes. If you want some, I will send them to you. Doug Bryant Wichita Ks ________________________________________________________________________________
Re: Pietenpol-List: Re: BPA Newsletter Reprints
Mike,My set arrived in the mail today -- not bad for a 1500 mile x-crosscountry -- probably faster than a Piet pretending to be a Mailplane! ;-)Mike ConklingPretty Prairie, KS----- Original Message -----
Hi Mike,I got my reprints last week, and wanted to thank you for making themavailable. I haven't started construction yet, but hope to soon.Many thanks,Mike Ellenberger----- Original Message -----
