Subject: Re: Pietenpol-List: stromberg carb>>Joe,>Can't promise but might run into one at Lucein Field. I'll go look tomorrow>and be in touch. Otherwise couldn't you tap in a size larger for a newplug.>After all that plug only keeps the float shaft in the carb.>Corky in La trying to dry out>>________________________________________________________________________________Date: Wed, 29 Aug 2001 22:41:13 -0500
Original Posted By: "fishin"
Subject: Re: Pietenpol-List: stromberg carbJoe,Can't promise but might run into one at Lucein Field. I'll go look tomorrow and be in touch. Otherwise couldn't you tap in a size larger for a new plug. After all that plug only keeps the float shaft in the carb.Corky in La trying to dry out________________________________________________________________________________
HELP---anyone out there have a dinged up stromberg carb that still has ausable lower float bowl. In removing the brass plug (which probably hasen'tbeen out in 50 years) most of the alum bowl threads came out with it. Onlyhave around a half turn of threads left for that brass plug and that's notan acceptable since it's my butt that's being pulled around by that big fanup front.I'm more then happy to cover any reasonable costs if anyone can help me.Check out those dusty shelves and cabinets, bet someone has one that gotbusted off at the mount from nosing over. I promise not to tell!!!JoeCZion, IL________________________________________________________________________________
Hi Corky, only about a 1/4 in of threads in there. the plug comes rightagainst the little thimble screen. we are considering retaping larger or ahelicoil but would prefer replacing the bowl. oh well, if all elsefails - - - -hope to hear from youJoeC99621-----Original Message-----
Re: Pietenpol-List: Tailwheel endorsement question
> _tried out the Stromberg carb today and what a difference.It started right away no hesitation =2Ckept going no need to keep priming.Lots of power.AME o take the Marvel home and see what he can find if anything is wrong with it.Must be something wrong with it because it worked fine before.> ============================================> > > ________________________________________________________________________________Subject: Re: Pietenpol-List: Tailwheel endorsement question
Original Posted By: Andrew M Eldredge
