Pietenpol-List: Re: wing ribs
Original Posted By: Dean Dayton
Hello Group!After finishing my wing ribs, I read a suggestion from BP, in the articla onthe Sky Scout that the diagonal brace aft of the rear spar should be from topto bottom rather than from bottom to top as shown on the original Aircamperdrawings. Is this critical? Could an additional brace be used to reinforcethis bay? It would not be too difficult to add a cross-brace diagonal withgussets, I suppose. What say you?Don CooleyP.S. Happy New Year!________________________________________________________________________________
Don, I think I read somewhere that someone was slipping a Piet in for a landing,and that a diagonal snapped. So Bernard switched it around to put it incompression instead of tension. With my limited knowledge, I'd say leave themthe way they are and don't do any hot dogging after you get her flying.________________________________________________________________________________
Re: Pietenpol-List: wing ribs
>>Hi,> We are getting ready to order our wing rib material. We will be>using a capstrip bending jig (Tony Bingelis EAA wood book), a capped>ABS pipe for steaming or bending the capstrip, and an Ord-Hume style>wing rib jig (EAA wood book).> For materials we have T-88 epoxy 1 quart kit, we will be ordering>spruce capstrips 3 pcs for each rib. One 6 ft pc (top capstrip and>diagonals), one 5 ft pc (bottom capstrip), and one 5 ft pc ( diagonals>and cross members). 5 square feet of mahogany poplar plywood for>gussets (we will probably order 8 ft, we believe that 1x4 and 2x2 pieces>are the smallest sizes available). We will be ordering our materials>from Wicks. We are using these materials because they are meet mil spec>and they will give us reasonably light ribs. Also they will be similar>to the joints that we will be using in other part of the aircraft (T-88>glue holding spruce stucture to mahagony gussets).> We are planning on stapling the gussets to the capstrips and then>removing the staples after the glue has set.> If anyone could let us know if we are on the right track or if we>are missing the boat we would greatly appreciate it.> Thanks again> Norm and Adrienne Decou> normdecou(at)sympatico.ca (new email address)>>________________________________________________________________________________Date: Tue, 7 May 2002 19:43:10 -0400
RE: Pietenpol-List: wing ribs
Hi Norm, Get ready for some fun! It sounds good to me, but do you reallymean 5 sq. ft. of plywood? I bought a 2 x 4 sheet (8sf) of mahogany plyand I will be a bit short on gussets, but not by too much. I have to orderanother sheet. Your capstrip is probably close, but then I cut my own fromboards and haven't really kept track. There's a list that calls out 500 ft,check this site. http://www.mykitplane.com/Planes/People ... d_List.xls Thisis a wood list from someone here on this list. I'm using staples too. I have a light duty stapler with light duty narrowcrown 5/16" staples. I got mine at ACE, about 8 bucks. The staples areround (versus flat chisel point) and it works great. I used an officestapler at first but it didn't seem to have enough 'oomph' to get thru theplywood. It's quick and easy, takes about 10-15 minutes to remove staplesfrom both sides of the rib when the T-88 dries. And that's about all I know about Pietenpol buildin'...Kent Hallsten Oklahoma CityMaking ribs like a madman________________________________________________________________________________
Sounds pretty close to the way I did it. I'll expand on Kent's commentsabout gusset material--I got a single 2x4 sheet and ran out. I wound upusing a lot of 1/16 inch plywood for gussets on the 1/2 x 1/2 root and tipbraces, and to make bearing plates where bolts would otherwise be in directcontact with spruce members. You'll also eventually need a whole 4x8 sheetfor the leading edge sheath unless you're using cardboard. Shipping costsare less of a problem if you get all of the really big stuff at the sametime.Have fun!Gene HubbardSan Diego with a new motor mount!________________________________________________________________________________
Re: Pietenpol-List:
Original Posted By: "Doc Mosher"
Good Idea! "yeah, yeah, thats the ticket"walt----- Original Message -----
Pietenpol-List:
Way to go Norm. I ordered 500 feet of capstrip from AS&S and it's just theright amount (a little extra for mistakes). Worked out perfect. I tried thesteaming part and didn't like it. I just put about the first 2 feet of thetop capstrip in a tube with just plain ol' water for 24 hours and thenformed them on the forming jig till the next day. They were dry the nextday. I formed 4 at a time and only made them every 3 or 4 days. Worked outgreat and you can't get burned. Much safer. They bend just as easily and youdon't have to rush it.It took me about an hour each evening to make one rib. I pre-cut all thediagonals and the gussets when I started the first rib and then glued thefirst side of the rib and let it set till the next day. I then took it fromthe jig and with the same batch of epoxy I glue the next rib's first sideand glued the gussets on the last rib's side #2. Once set up, it was 1 ribin 1 hour per day.I was done in a month.Good luck, it's very satisfying.George AllenHarrisburg, PAGeorgeA(at)PAonline.com(Peitenpol builder) Ribs, horiz. stab & elevators done.>Subject: Pietenpol-List: wing ribs>> Hi,> We are getting ready to order our wing rib material. We will be> using a capstrip bending jig (Tony Bingelis EAA wood book), a capped> ABS pipe for steaming or bending the capstrip, and an Ord-Hume style> wing rib jig (EAA wood book).> If anyone could let us know if we are on the right track or if we> are missing the boat we would greatly appreciate it.> Thanks again> Norm and Adrienne Decou> normdecou(at)sympatico.ca (new email address)________________________________________________________________________________
Go for it, Norm! Sounds like you're on the right track. I did much thesame thing, although I used nails instead of staples (I found the staplessplit the plywood too often - probably just my poor technique).Jack -----Original Message-----
Norm and AdrienneSomeone on the list ( I can't remember who ) glued up his ribs in the jig and then carefully removed them before fixing on the gussets. The gussets were then just glued on both sides at once and held with clothes pegs.I have started my ribs and gave it a go. It works perfectly and with a little square of wax paper under each joint there is no problem with gluing up things you don't really mean to.One thing I have been very careful with is getting a really accurate join between the capstrips and braces. It takes a little more effort, but I think it is worth the extra time.Good luck with whichever method you chose, one thing's for sure, there are many ways of building a Piet and many able and experienced builders out there willing to help out us beginners.Cheers,Rod woollerAustralia>From: Norm Decou >Reply-To: pietenpol-list(at)matronics.com>To: pietenpol-list(at)matronics.com>Subject: Pietenpol-List: wing ribs>Date: Tue, 07 May 2002 13:02:16 -0400>>>> We are planning on stapling the gussets to the capstrips and then>removing the staples after the glue has set.> If anyone could let us know if we are on the right track or if we>are missing the boat we would greatly appreciate it.> Thanks again> Norm and Adrienne Decou> normdecou(at)sympatico.ca (new email address)>>________________________________________________________________________________
In describing his method of rib making, rod wooler said:> One thing I have been very careful with is getting a really accurate join> between the capstrips and braces. It takes a little more effort, but Ithink> it is worth the extra time.Depends on your criteria. Precise workmanship is always satisfying,and you seem to be making an extra effort in one area so as to reducethe time spent in another. (Though if you'd just put the gussets onthe first side, you could have removed the rib without waiting for theglue to dry.) Aside from that, those joints won't do much for theairworthiness of your rib. The verticals and diagonals simply transferstresses from the top and bottom surface to the gussets, which take upall the loads that attempt to deform the ribs, rather than being routedinto the spars. They would do that just as efficiently if you lopped theends off square and left big, triangular gaps between them and theupper and lower capstrips. As many efficiency-minded builders havedone, without any problems.That said, I am fitting the ends of mine as well as I can. Those gapsmay be harmless, but they are aesthetically unsatisfying.Owen Davies________________________________________________________________________________
Original Posted By: rod wooller
This method soudns great, but how do you support the rib while the gussetsare glued? How do you keep it flat with all those pins? Also, how do youkeep the gussets from sliding?Thanks,Ken, still getting the fuselage sides together in Austin, Texas, and lookingforward to ribs.----- Original Message -----
RE: Pietenpol-List: GLUE
Building ribs is a delight with aerolite. Put the pookey on the spruce andI used a tooth brush for the activator and just coated the entire side ofthe gusset with a toothbrush.Chris Bobka-----Original Message-----
The Waco Airplanes ribs were made with squared off ended loose fittinguprights and diagonals in the ribs. Indeed, the load is transferred to thegusset in shear although the gussets are a bit larger. I would make thegussets 30 to 50% larger in each dimension (except thickness) and disregardthe close fit of the uprights and diagonals.chris-----Original Message-----
Christian Bobka advised:> The Waco Airplanes ribs were made with squared off ended loose fitting> uprights and diagonals in the ribs. Indeed, the load is transferred tothe> gusset in shear although the gussets are a bit larger. I would make the> gussets 30 to 50% larger in each dimension (except thickness) anddisregard> the close fit of the uprights and diagonals.Couldn't hurt, aside from adding a tiny bit of weight. ButI'd guess that the gussets were bigger on the Wacos becausethey were expected to carry a larger load, not because ofthe way the uprights and diagonals were cut. The Wacoswere just a whole lot heavier than the Piet, and the open-pitversions were probably stressed for some aerobatics.Owen________________________________________________________________________________
Re: Pietenpol-List: GLUE
Christian Bobka observed:> Building ribs is a delight with aerolite. Put the pookey on the spruceand> I used a tooth brush for the activator and just coated the entire side of> the gusset with a toothbrush.Annoying as blazes, though, when you pull the staples and the gusset comesup with them, and it suddenly dawns on you that you forgot the activator.Someone suggested putting a little food dye in the activator so that itleavesvisible evidence of its presence. Not a bad idea.Do remember that the latest version of AC 43.13-1b specifically removesFAA approval from Aerolite-type glues, owing to the deterioration ofjoints in sun-baked areas.It's getting so I don't want to use anything but resorcinol.Owen (in sunny Florida)________________________________________________________________________________
Original Posted By: Kip & Beth Gardner [mailto:kipandbeth(at)earthlink.net]
If you're doing the three-piece wing, don't forget the eight 2 inch x 5 footpieces for the root reinforcements. With the 4x8 sheet, I had almostexactly enough for the L.E. and the root reinforcements. As it was, I hadto piece together two of the root pieces (lower surface of the centersection--used an inside doubler for strength--nobody will EVER see it...).There wouldn't have been enough left over for gussets.Gene-----Original Message-----
Original Posted By: ANNCARLEK(at)aol.com
Did the whole plane with Aerolite, and other than getting it acrossthe border into Canada, it was hassle free. Imagine two 1 kilo bags of"white powder" and a tough Customs Officer.________________________________________________________________________________
Original Posted By: "Ian Holland"
Subject: Re: Pietenpol-List: wing ribsIn a message dated 5/8/02 8:02:12 AM Eastern Daylight Time, rodwooller(at)hotmail.com writes:> One thing I have been very careful with is getting a really accurate join > between the capstrips and braces. It takes a little more effort, but I think > > it is worth the extra time.One good thing about getting good accurate joint, there is more surface area there for glue to stick to. That can't help but make a good strong joint. The gusset should be good close fit too. Clamping pressure should not be so heavy that all the glue runs out of the joint either ! Little glue coming out is good sign of proper clamping though.Ever try testing to destruction one of your ribbs ? They are STRONG if built correctly.-dennis the menace________________________________________________________________________________
Original Posted By: John_Duprey(at)vmed.org
Owen,The main reason for making a close fit in the joints is so the rib doesn't fall apart when I remove it from the jig as there are no gussets to keep everything together.I am probably making extra work for myself, but it's a labor of love.Rod W.>From: "Owen Davies" >Reply-To: pietenpol-list(at)matronics.com>To: >Subject: Re: Pietenpol-List: wing ribs>Date: Wed, 8 May 2002 09:09:12 -0400>>>In describing his method of rib making, rod wooler said:>> > One thing I have been very careful with is getting a really accurate >join> > between the capstrips and braces. It takes a little more effort, but I>think> > it is worth the extra time.>>Depends on your criteria. Precise workmanship is always satisfying,>and you seem to be making an extra effort in one area so as to reduce>the time spent in another. They would do that just as efficiently if you >lopped the>ends off square and left big, triangular gaps between them and the>upper and lower capstrips.>>Owen Davies>>________________________________________________________________________________
Re: Pietenpol-List: damp shop
05/09/2002 07:54:58 AMSounds like it is time to add a sump pump. The dryer you can keep the airthe better. But you work with what you have.________________________________________________________________________________Date: Thu, 09 May 2002 08:11:09 -0500
Original Posted By: Borodent(at)aol.com
rod wooller wrote:> The main reason for making a close fit in the joints is so the rib doesn't> fall apart when I remove it from the jig as there are no gussets to keep> everything together.> I am probably making extra work for myself, but it's a labor of love.Understood. It's why I bothered to fit the uprights and diagonals socarefully, even though I was putting the gussets on in the jig andI know the extra effort doesn't give any practical benefit. Enjoy.Owen________________________________________________________________________________
Original Posted By: catdesigns(at)juno.com
ChrisWas there any problem with the gussets slipping when you first squeezed themon?Also, how did you keep the rib flat when it had binder clips all over?ThanksKen----- Original Message -----
All this talk about wing ribs has kept nagging me about what I did. Or, ratherwhat I didn't do. I didn't scuff the mahogany plywood with sandpaper beforecutting it up into gussets. Will this be a problem for me? Almost half the ribsare done now. Please comment.Kent Hallsten________________________________________________________________________________Date: Fri, 10 May 2002 22:51:24 -0500
> Pietenpol-List: OT - But aircraft related
Kent Hallsten wrote:> I didn't scuff the mahogany plywood with sandpaper before cutting it up> into gussets. Will this be a problem for me?Not likely. The scuffing is needed more for birch plywood than formahogany.Mahogany doesn't seem to "glaze" the way birch does. Couldn't hurt to scuffthe rest of your gussets, but the ones you have should do fine.Owen Davies________________________________________________________________________________
Original Posted By: Norm Decou
Ken,I thought about the difficulty in gluing gussets to both sides at once, so I set up the rib on a couple of soup cans and glued the gussets on one side at a time using small spring clamps to hold them.Rod W.________________________________________________________________________________Date: Sun, 12 May 2002 00:23:36 -0400
Re: Pietenpol-List: wing rib drawings
Subject: Re: Pietenpol-List: wing rib drawings
>>Actually there is a concern. because mine was 3/4>inches off on the spacing of the spars, and an inch>off on the entire cord width. I solved my dilemma by>buying a set from charlie rubech.>Del________________________________________________________________________________Date: Mon, 13 May 2002 15:23:52 -0700 (PDT)
JohnLook at the Bowers Flybaby, it uses plywood ribs. The conclusionfrom what I looked into is that the Plywood rib is much heavier than that ofthe traditional builtup rib. A rib that is lighter than that of the traditional method is one that I believe was incorporated in the Longster of the 1930's. It uses no gussets and two cap strips on top of the rib and two on the bottom with the crossmembers sandwiched in between.Bruce________________________________________________________________________________
Re: Pietenpol-List: T-88 vs. resorcinol
GaryAre you sure it was caseine glue and not hide glue.Most furniture used hide glue and still do.Put it in a heat pot and spread it on.Dale----- Original Message -----
Subject: Re: Pietenpol-List: wing ribsIn a message dated 11/30/2006 1:58:44 PM Central Standard Time, amsafetyc(at)aol.com writes:Has anyone attempted to use a plywood wing rib, cut from plywood sheet material rather than a built up rib, if so what were the results in terms of strength and weight?Plywood wing ribs are much heavier, and not all that much easier to build.Chuck G.NX770CG________________________________________________________________________________
Re: Pietenpol-List: Icarus Plummet axle failure
MessageJack,Did adding brakes force you to use an axle that is longer than the F&G plans?NX18235 is brakeless and is using 1 1/2 X .120 tubing. I have made some horrifically hard landings at 1100 pounds with no sign of axle bending.Greg CardinalMinneapolis ----- Original Message -----
Rick,Yes, the John Deere that WW and Mark Langford suggest.The wing is moved back about 2" (cabanes leaning back).It (flies) (fly's) is flying slightly nose heavy.Probably should move the wing forward slightly 1/2" (1 1/2" leaning back)may be this winter.FYI, I did not take extreme measure to build light, simply build to theplans and weight should not be a problem.Hans. "Rick Holland" To Sent by: pietenpol-list(at)matronics.com owner-pietenpol-l cc ist-server@matron ics.com Subject Re: Pietenpol-List: Fuse questions... 12/01/2006 08:52 AM Please respond to pietenpol-list@ma tronics.com This gives me new hope that I can build my long fuselage Corvair atsomething under 700 lbs. Do you also have an altenator Hans? Or justrecharge your battery in the hanger? Also, did you have to move your wingback to get your CG right?ThanksRickOn 11/29/06, Hans Vander Voort wrote: hans.vander.voort(at)alfalaval.com> Just to compare. My Pietenpol, long fuse with a Corvair, split landing gear, three piece wing and poly fiber covering weights empty at 680 Lbs. No deviations from the plans other than longer Cabane struts (2 inch), center section cut out (no flop) and piano hinge ailerons That makes it only 4 Lbs heavier than Roman's steel tube fuselage with a similar setup. Oh....and I have an electric starter and battery on board.--Rick Holland"Logic is a wreath of pretty flowers, that smell bad"________________________________________________________________________________Subject: Re: Pietenpol-List: wing ribsDate: Fri, 01 Dec 2006 11:07:21 -0500
I attached a pic of my set up. I bought a blemished interior door for $5 and set up jig for one rib. After making one, I duplicated twice, now I make 3 at a time. If anyone is wondering, the sockets hold the glued gusset plates in place so I dont have to staple.Dick N.________________________________________________________________________________
Original Posted By: raymond smith
> >> >> >> We are planning on stapling the gussets to the capstrips and then> >removing the staples after the glue has set.> > If anyone could let us know if we are on the right track or if we> >are missing the boat we would greatly appreciate it.> > Thanks again> > Norm and Adrienne Decou> > normdecou(at)sympatico.ca (new email address)> >> >>>________________________________________________________________________________Date: Wed, 8 May 2002 12:01:10 -0700 (PDT)
