Subject: Pietenpol-List: WedgesGene: I posed the question about the wedges yesterday. It wouldn't be aproblem to cut long wedge strips if I had the wood on hand to do it.Ibought a wood kit from Gene Peters where all of the pieces are cut andmilled pretty close to exact demension with only small pieces left overafter cutting to proper length. they are short enough to be worrysome(fingers!) when cutting on a table saw. The spars came 'flat top' sobeveling is out of the question any way. I guess I'l have to order oneof those spruce grab bags. Thanks for the tips. Leon S. Do ot archive________________________________________________________________________________Date: Fri, 9 Aug 2002 07:21:51 -0700 (PDT)
Original Posted By: ANNCARLEK(at)aol.com
Subject: Pietenpol-List: WedgesDel: Thanks for the tip on using alternate for these wedges. That wasso simple i never thought f it. I am always making things harder thanthey have to be. Dick H. ...."are these wedges really needed"? Thatsan interesting question. BHP used no verticals at the spars so he had towedge the ribs to mount the ribs to the spars. In his case, yes it wouldadd the needed strength. And its the only way he had to fit the rib capsto the spar top.I, like most of us have put a vertical 'stick' at thespar opening. By gluing the vertical to the face of the spar I wouldthink you would have all the strength needed without the wedges. I'm noengineer, so I am going to use the wedges. (like wearing a belt alongwith suspenders) Gene H. ..."imperfections in your ribs will show, sobe prepared to sand." I noticed that in making the 4 wedges used in mycenter section. The front left wedge fit tight but was loose in thefront right position, etc. This what got me thinking in the first placethat there had to be an easier way. It looks like every wedge would needto be custom made and custom fitted to a specific location. that couldtake weeks! ah well, Its all part of the game. I don't mind doing stuffas long as it don't end up in the dammit box. Thanks. Leon S. in rainyKS. where it is raining for the first time since mid May.________________________________________________________________________________
Re: Pietenpol-List: Wedges
Original Posted By: Leon Stefan
It doesn't have to be any particular kind of wood . . . any wood will do.Just cut a two ro three foot length with a bevel on it and start slicing. Iwouldn't wait for a grab bag of spruce, I'd go to Home Depot and find anypiece of good looking spruce or fir.Gene----- Original Message -----
Original Posted By: Matt Naiva
Original Posted By: clif
Subject: Pietenpol-List: WedgesIn a message dated 8/9/02 10:05:44 AM Central Daylight Time, rhartwig11(at)juno.com writes:>That's what I did.Chuck Gantzer________________________________________________________________________________Date: Fri, 09 Aug 2002 23:40:10 -0700
Well while I'm at it.for the fuselage sides are people using wedges on alljoints between gusset plates? Or just on joints forward of the rear seat?Thanks once again,JackDSM________________________________________________________________________________
Original Posted By: Jack
just the forward ones, they are there for the bolts for the struts/gear fittings.Gene ----- Original Message -----
RE: Pietenpol-List: Wedges
Just the joints where the landing gear struts and lift struts attach.Jack PhillipsNX899JPRaleigh, NC _____
