Subject: Re: Pietenpol-List: Built up Spar>>Matt,>I have a good article on designing built up spars. Send an SASE to me>for a copy.>>Greg Cardinal>5236 Shoreview Ave. So.>Minneapolis, MN 55417>>>>> steamlaunch(at)softhome.net 08/09/02 11:27PM >>>>>>Hello,>>Has anyone ever used a built up spar with a plywood web on a piet? Would>it still be>considered a piet. BP laminated Spars out of dimensional wood. This>would merely be a>variation of the theme.>>Matt>>>http://www.matronics.com/browselist/pie ... ______Date: Thu, 15 Aug 2002 09:58:29 -0700 (PDT)
Pietenpol-List: white ash axle blocks
GregI have heard of the box spar that I think you were talking of at one timebut a biult up spar? I don't remember hearing of this on the list. Could youpost this on the web somewhere and let us know where it is at.Ken-----Original Message-----
Original Posted By: "Ken Maynard"
Hello,What would be your favorite tool for making a clean 12/1 scarf cut on a 1x1"doug fir longeron. I have a table saw and a cut off saw but cannotunderstand how to do this accurately enough to create a good glue joint.Do I not have the right tools or am I just missing the expertise to makethese cuts clean and accurately.Ken________________________________________________________________________________
RE: Pietenpol-List: Two GN-1's for sale on e-bay
Ther second one is mine. It's the one I bought in April. I bought itfor some odd and ends that I wanted to tale from it. I ended up takingthe control stick, rudder pedals tail flying wires and a few otherthings. Overall the plane is still 85% intact.I was thinknign of finishing it but I don't have the time nor do Ireally think I want 2 GN-1's.Any questions ..... Email me.DJ Veghwww.raptoronline.com-----Original Message-----
RE: Pietenpol-List: Built up Spar
Original Posted By: Ken Maynard [mailto:ken(at)polarcomm.com]
Ken,I use a router, with a flat end bit.For the jig you need 3 pieces of wood, (1) 3/4 X 4 X 15, (2) 1/2 X 2 X 15.Now attach the 2 smaller pieces to the sides of the 3/4 X 4 piece in such away that the top edge of the sides form a 12/1 slope.The router rides up and down this slope while the 1 X 1 is secured to thesurface of the 3/4 X 4.I like to draw a 12/1 line on the side of the work and cut close to the linewith the band saw, before routing, this saves time, router bits and sawdustcleanup.Do the above to two pieces of wood, glue them together and you will have aperfect scarf joint.I hope I was able to explain the jig well enough.Skip-----Original Message-----
Subject: Re: Pietenpol-List: Built up SparKen,I cut mine on the table saw by staggering the pieces and feeding them thru the saw at the staggered angle with the saw blade slightly below the thickness of the wood for containment. This method works very well for me, and I scarf alot of wood. Doug Bryant________________________________________________________________________________
