Pietenpol-List: radios
Original Posted By: "Ken Goff"
Hey allI am looking to order a VHF handheld. Looking in ACS, I see some models with VOR'sin addition to Com.I was looking at adding an external antenna on the fuse belly. Does anybody usethis model with Nav/Com? Can you add an external antenna? With just the standardantenna do you have a satisfactory range? I'm not sure I even need thatfeature, I have a small GPS. Dick N.________________________________________________________________________________
Re: Pietenpol-List: radios
Dick,I have an external on the belly. Have a King KX99. Tried the VOR once tosee how it works. Never use it. I suppose it would be a backup if the GPSgave out. Costs about $100 more for the VOR.There is a 24" square plate of aluminum on the inside of the belly for aground plane. Have lots of range. Works good.On the one I am building I want to put an internal antenna just to avoid onemore thing that takes away from the 30s look.Coming to SnF?Ted----- Original Message -----
TedYes, I'll be at SNF a day or two early, camping in the same area, hopefully.Thanks for the input on the radio. I was all set to order it, but decidedto wait to see what is at the Fly Mart at SNF first.Catch you laterDick----- Original Message -----
Original Posted By: clif
Re: Pietenpol-List: UV test of Latex Paint
