Pietenpol-List: Cessna gear
Original Posted By: Doc Mosher
Subject: Pietenpol-List: Cessna gearCorky: I toyed with the ides once, but that was about it. I had a set ofCessna gear legs at one time. They have a small mounting area that Ifelt (although I'm not an engineer) could be easily be ripped out ofwood in a hard landing. So you would need to add a large steel plateunder the floor board to spread the mount load over a larger area. Ithink you would also need to weld this steel plate to another piecethat you would want to run up the outside of the fuselage and tie itinto some of the fus. bracing. I think it could be done. I never weighedthe Cessna gear, but my tube gear legs are lighter. Leon S. HutchinsonKs.________________________________________________________________________________Date: Sun, 04 May 2003 16:20:29 -0500
Re: Pietenpol-List: N3141J
Original Posted By: "Doc Mosher"
I ran into Joe the other day. He's up in the NJ area and stopped in to seemy Pietenpol. He was telling me about His plane some. Seems he wassurprised at how light mine was empty at 595#, seems his is in the mid800# range. Since I'm a fan of Poly Fiber , I was surprised to hear thathis paint process was a case of Krylon. Oh well,,,guess thats why they callit "experimental".waltglad in the end that I didn't cut corners, and built to the plans----- Original Message -----
