Terry,I tried emailing you and the address bounced.I found a spring source, the plans for the spring struts and the drawing for thelanding gear jig.Email me offlist and I will get you a copy of this stuff.I don't have a scanner so if someone with a scanner wants to contact me maybe wecan get a copy of this stuff on a web page somewhere.Regards,Bob SeibertNX23TX________________________________________________________________________________Date: Wed, 24 Sep 2003 11:19:48 -0500 (GMT-05:00)
Pietenpol-List: Springs and landing gear
Re: Pietenpol-List: Springs and landing gear
Original Posted By: ANNCARLEK(at)aol.com
Subject: Re: Pietenpol-List: Springs and landing gearA company that specializes in springs (including custom wound springs) is Lee Spring Company, 1462 62nd street, Brooklyn, NY 11219, 718/236-2222, http://www.leespring.com/ ..........Carl Vought________________________________________________________________________________
Pietenpol-List: Re: Springs and landing gear
Original Posted By: ""
Jim,There is a copy of the spring strut drawing and landing gear jig in the mail toyou today.These are the drawings I used to build my gear which is working real well (so far).I adjusted the height to accomodate 18" motorcycle wheels vs. the 6.00 x 6 wheelsthat the drawing is for.Hope you can post them somewhere.I lost the receipt for the springs I used but they can be bought over the internetpretty easily.If you do a Google search for "Die Springs" you will get a lot of hits for suppyhouses.I used the 1 1/2 OD X 6 Gold springs. (The gold color indicates they are heavyduty)Here is one of the links that I found. http://www.diesupplies.com/catalog/springs/27ehr.html I think thats where I got mine but I can't swear to it.Regards,Bob SeibertNX23TX________________________________________________________________________________Date: Thu, 25 Sep 2003 10:11:25 -0500
Re: Pietenpol-List: fuselage weight - setback - McGregor Fly-in
Original Posted By: Gnwac(at)cs.com
Subject: Re: Pietenpol-List: Springs and landing gearTo Bob Seibert Hi Greg Menoche, first time builder of a Piet and first to the list. I have a drawing from Bill Rewey. Is this the same design you refer, and where did you find the springs?________________________________________________________________________________
Original Posted By: Seibert Bob-r18643
Subject: Re: Pietenpol-List: Springs and landing gearThanks for the spring address. Are you using Bill Rewey's design or another?Greg________________________________________________________________________________
Pietenpol-List: Re:Springs and landing gear
Yes, the spring landing gear setup is from the Rewey drawing.It works fine so far and I just used a generic "heavy duty" die spring of the dimensionslisted.They needed a little shimming but work great.Regards,Bob Seibert________________________________________________________________________________Date: Mon, 29 Sep 2003 10:04:15 -0500 (GMT-05:00)
