Pietenpol-List: Material strengths
Original Posted By: "DJ Vegh"
Subject: Pietenpol-List: Material strengthsPieters,Ran across a couple pieces of streamline tubing left over from front struts of 41CC. 2 1/2X7/8X.049. Have some smaller pieces also. What my question is, Could I sub this streamline tubing for the round in the fabing of the split gear? Would it be strong enough for some of Nathan Moss's landings ( I questionhis depth perception sometimes)Corky in cold La________________________________________________________________________________
Re: Pietenpol-List: Material strengths
Subject: Re: Pietenpol-List: Material strengthsIn a message dated 1/27/04 9:21:55 AM Central Standard Time, Isablcorky(at)aol.com writes:>Corky,The plans call for 1 3/8" 14ga. (.074") 1020 steel tube for the Vee gear struts. As tempting as it may be to use the 2 1/2" X7/8" X.049", I just don'tthink it would be adequate for a gross weigh, drop it in type landing.Chuck G.4 F outside, calm winds - Hearty individuals like Shawn Wolk and Graham Hansen, call this 'Pietenpol Weather' !!!________________________________________________________________________________
Subject: Re: Pietenpol-List: Material strengthsIn a message dated 1/27/2004 10:48:21 PM Central Standard Time,Rcaprd(at)aol.com writes:> Chuck G.> 4=BA F outside, calm winds - Hearty individuals like Shawn Wolk and Graham> Hansen, call this 'Pietenpol Weather' !!!Chuck,Its good weather to be inside making Pietenparts.Terry Bowden(making some rudder cable extensions getting ready to move the non-plansrudder pedals 6 inches forward for more legroom)________________________________________________________________________________
Subject: Re: Pietenpol-List: Material strengthsThanks Chuck,I have the plans tubing on hand and will use it accordingly. Would like to hear of your/our Post Brodhead tour and what plans you may have finalized.Corky in La trying to keep his feet warm________________________________________________________________________________
Check the Aircraft Spruce Catalog; there is an equivalent round tube vsstreamlined tube comparison for tensile and compresssive strength.Lou larsen----- Original Message -----
