Pietenpol-List: Aluminum rims if you can.........
Re: Pietenpol-List: Aluminum rims if you can.........
Ah, but remember, steel is stronger, and less is used to come up with the samestrength.Dan Bailey,Paola, KS ----- Original Message -----
Mike,I've held comparable steel and aluminum rims, one in each hand, to compare theweight. No scale was available but the weight differencewas far less than I expected. If you can find aluminum rims use them but don'tlet steel rims be a show stopper.Greg Cardinal ----- Original Message -----
