Chuck.... No dissassembly required for prop strikes on Experimentals,especially prop strikes with wooden props. Only mandatory on CertifiedAirplanes and "maybe" an experimental with a Metal prop. I'm sure Steve willdial the crank and that's all he should need to do. The engine was rotatingat idle probably too and not generating a lot of damaging energy. Note thefact only one prop blade was wiped out.Good Luck Steve E... I know you guys can get it squared away in time.Weav----- Original Message -----
Pietenpol-List: Good Luck Steve E!
RE: Pietenpol-List: Good Luck Steve E!
Re: Pietenpol-List: Good Luck Steve E!
Steve.... It really is that simple. AND if the flange isn't bent, (I don'tknow the limits) I wouldn't tear the engine down at all. Just run it...Weav----- Original Message -----
