Pietenpol-List: Need a little help
Original Posted By: Woodflier(at)aol.com
Subject: Pietenpol-List: Need a little helpPieters As I am before installing my A-65, I have that Stromberg Carb without a mixture control device. Not being familiar with this device I would greatly appreciate if some knowledgable soul would pour out his wisdom on this subject and guide me through the process so I can finalize my instrument panel controls. I definitely want the mixture control if its available without too much adaptation or expense. I just don't know what's involved. ThanksCorky in lean La________________________________________________________________________________
Re: Pietenpol-List: Need a little help
Corky,I just has my carb overhauled and the guy that did it in Sebring, FL saysthat a mixture control can be put on.DickG.Ft. Myers, FL________________________________________________________________________________
Original Posted By: "Richard Gillespie"
Subject: Re: Pietenpol-List: Need a little helpThanks for the reply. Would like his name and address, phone and/or email if possible. Have you heard of many A-65s w/ mix control. I'm sure the L-4s had them in WWII but I don't know. Everyone says it's not needed. That's what they say about a chute in a Piet also.Did you receive the picture of YOUR brake parts mounted in MY Piet?Corky________________________________________________________________________________
Corky,His name is Wiggins dba Aircraft Accessories of Sebring, Inc. 2610 Lake Denton Rd. Avon Park FL 33825 tele 863/452-2925Haven't recieved the picture yet. I just installed the carb and aircleaneryesterday and now have the throttle, carb heat and gas shut-off controlsinstalled. Waiting on tach to finish instruments. I haven't seen any 65'swith mixture controls but I'm sure they're out thereDickG.Ft. Myers, FL________________________________________________________________________________Date: Sat, 7 Apr 2001 10:51:27 -0700 (PDT)
Original Posted By: dave rowe
Subject: Pietenpol-List: Need a little helpPieters,When I built 41CC one of the highest hurdles and time consuming projects was the fabrication and installation of the fuel plumbing particularly the cut offvalve and remote control. I am at that stage again and would like as many solutions as you would feel free to share with me. I have an 18 gal fuse tank just rear of the fire wall. I need a on-off valve easy enough to operate with apush pull wire.ThanksCorky in La________________________________________________________________________________Date: Sun, 14 Mar 2004 17:29:47 -0800
Corky,How about a twist instead of push pull? I turn mine 90 degrees for full on tooff.Ted ----- Original Message -----
Original Posted By: "DJ Vegh"
Subject: Re: Pietenpol-List: Need a little helpIn a message dated 3/14/04 5:39:01 PM Central Standard Time, Isablcorky(at)aol.com writes:>Corky,I'll e-mail you direct, with some digital pictures (still in the camara) of how I did mine. Might give you some ideas.Chuck G.________________________________________________________________________________
Original Posted By: "William Koucky"
Pieters,I am busy doing the rigging of the elevator and rudder, no where can Ifind what the travel should be, need to know the elevator up and downdeflexion in degrees/ inches as well as for the rudder left/ right.Waiting for the spare from AS&S then I have to cover the fuselage andthen assemble.Thanks in advanceNorman StapelbergZS-VJA (rebuilding)________________________________________________________________________________
