Pietenpol-List: The A-75 is a production engine
Original Posted By: "Bert Conoly"
Bert,To answer the first question, the A-75 is a production engine. The firstversions of it were fuel injected, the -8J, but this later gave way to thecarbed versions, the -8 being most common. Some of the A-75s have the -9crankcase and accessory case allowing it to have a starter, either theHummer X which is a bungie stretched the length of the fuselage that isliterally geared to the crankshaft via an overriding clutch (wow) andsimilar to the wind up the spring and release lawn mower engines, theMcDowell, which is tantamount to a pull start on a lawn mower, or an Eclipse385 ( I think that number ) which is an electric starter run off of abattery as the case does not have a provision for a generator.The fuel injected engines, or formally fuel injected engines, would have aboss forward of the intake spider where the injector pump would be drivenoff of. It is identical to what was used on the O-200s to drive the vacuumpump. A block off plate might be installed here. The -9 also came fuelinjected as the -9J. I believe that B and S makes a small dynamo that canbe mounted on a vacuum pump pad and this might be a simple way to have anengine driven electrical system (although you might need a transponder then,depending upon where you live).Chris----- Original Message -----
Re: Pietenpol-List: The A-75 is a production engine
Hi Chris,You wouldn't know were a guy could find one of those bungee starters, wouldyou?Got pictures of one on a Piper J-5A and I think it would be neat to have oneon mine.Al----- Original Message -----
Original Posted By: "Al Latham"
Al,I have one that I bought on ebay a few years ago although it is incomplete.It took me a few months just to figure out how it worked. The problem withit is twofold. First is that you have to have a -9 case. Do you have a -9case and I mean crankcase AND accessory case? Second is that it does nothave an oil seal where the shaft exits the oil side of the unit so thestarter has a built in oil leak. Still interested?Chris----- Original Message -----
Chris,You paint such Rosie pictures... I do have a -9 set-up. Is there any waythat you can seeto modify the unit to incorporate a oil seal, Having a J-5 with a slickblack belly isn't somethingI'm very interested in...From what I've seen, I'm just starting to look into jacking up the HP on anA-65, with someparts / $$$ you can take the A-65 all the way to an A-80.You can e-mail me at goldnav(at)ipa.net, just put Al Latham in the subjectline. With my new jobI'm only at this address on some weekends.Thanks,Al----- Original Message -----
