Subject: Pietenpol-List: Re: Speaking of VideoSign me up, too! Sounds like a great help. Don Cooley________________________________________________________________________________Date: Tue, 29 Jun 2004 18:53:11 -0500
Re: Pietenpol-List: Turtle Deck Stringers
Think about it, Rick. Unless the top longerons are EXACTLY straight from thefront support to the rear support, then the stringers HAVE to be bowed. Nowmaybe the top one(s) can be straight but the ones closest to the toplongerons will most likely be bowed some or even quite a bit.....Chris----- Original Message -----
RE: Pietenpol-List: Turtle Deck Stringers
Rick,I made mine dead straight from front to rear. It's the straight line of thestringer that will show though the fabric.Check out http://www.cpc-world.com for more info.CheersPeter.-----Original Message-----
Rick,I made mine dead straight. The original plans called for those arches withnotches in them, then I saw the ones that made the "broom". I opted for thebroom, with each piece of a support a separate "stick" with a notch. Withlots of sticks, and lots of clamps, you can support the stringers from frontto back thru two stations by sighting along the stringers and adjusting thebroom pieces till all is good. Then I marked each piece and outlined itwith pencil, so i could be glued correctly.They say the judges at Oshkosh sight down the stringers for the "big prize":)walt evansNX140DL----- Original Message -----
