Pietenpol-List: To the Fl., Ga., and Alabama guys and gals....
Hunker down and God be with everyone in the path of Frances. Larry Ragan Jacksonville, Fl. lragan(at)hotmail.com ________________________________________________________________________________Date: Thu, 02 Sep 2004 23:27:06 -0700
Re: Pietenpol-List: tailhook
CliffI took a look at this hook, good idea but maybe a snapshackle used on a boat wouldbe simpler. I dont have one at home here to send a pic.Dick ----- Original Message -----
RE: Pietenpol-List: To the Fl., Ga., and Alabama guys and gals....
Original Posted By: "Mike"
Hope everyone survived o.k. What a b..ch Frances was. We've justnow had our power turned back on, and the people from Daytona and south got hammered.Thanks to all of the volunteer utility companies that come down to get thingsback to normal. We saw several convoys of bucket trucks from N.C., headedsouth yesterday. They're our heroes.Larry Ragan Jacksonville, Fl. lragan(at)hotmail.com ________________________________________________________________________________
Re: Pietenpol-List: welding
Please understand what the message is regarding welding. Yes, with the properknowledge and equipment, 4130 can be MIG welded, or TIG welded or diffusion bonded,or even glued into bicycle-type fittings. Done properly, MIG welding cansave hours of work and produce beautiful and very reliable assemblies.HOWEVER, for the normal homebuilder, who has a competent hobbyist's skill level,cannot or will not spend the money on a heat-treat oven, and/or won't be ableto subject his work to the rigorous inspection that is performed by most liability-consciousmanufacturers, oxy-acetylene welding provides the safest andcheapest way to fabricate a strong assembly of 4130.Mike Hardaway ----- Original Message -----
Hello Larry I lost power for about 24 hours here in Macclenny. Bunchof limbs and braches lying around. Jacksonville schools were closedtoday thus I don't have to go to work.John C.-----Original Message-----
Re: Pietenpol-List: To the Fl., Ga., and Alabama guys and gals....
Original Posted By: Larry Ragan
The Fla., Alabama and Georgia guys (as well as workers from Tenn., MO and a bunchof others I didn't recognize the markings on the truck) were OUR heroes lastSeptember when NC and VA got hit. None of us will ever be even, and maybe that'sgood.Hank (Took 9 months for the airport to fix my hangar door so I could get my planeout!) J ----- Original Message -----
Original Posted By: "Ralph"
Subject: Re: Pietenpol-List: weldingIn a message dated 9/6/04 7:40:33 AM Central Daylight Time, aquanaut(at)indy.rr.com writes:>I use oxy / accy for any thin wall tubing. Mainly, because it works, it's relatively inexpensive...and it's all I've got !! However, when the time comes,I'm going to tack weld my Wittman Tailwind fuselage together with a borrowed mig, then finish weld the entire airframe with oxy / accy, including completely welding through the tack welds.Chuck G.________________________________________________________________________________
