Original Posted By: "cgalley"
Subject: Pietenpol-List: Continental Engine Mount BoltsRegarding the bolt A65 bolt diameter, it was my understanding that the plans were in error and the bolt should be 3/8" instead of 7/16". I think I have in the archives stating that some have had problems because of this. I have some detailed drawings of the engine from Continental and it would appear that the bolt is 3/8". Please let me know if I am wrong because I have just finished building a steel motor mount jig and will start fitting the tubes in a couple ofdays. Buying the bolts will be my last step to make sure I have the right length.Craig Carter________________________________________________________________________________
Re: Pietenpol-List: Continental Engine Mount Bolts
Original Posted By: CraigAlanCarter(at)aol.com
My Continental Manual says that it is a 3/8" bolt, page 14 upper left hand cornerof the drawing.Cy Galley - Aeronca Aviators Club Newsletter Editor & EAA TC www.aeronca.org Actively supporting Aeroncas every day ----- Original Message -----
It is also 3/8" as shown on p 19 of the C-75, C-85 manual. Same rubber bushing,Same part number.Cy Galley - Aeronca Aviators Club Newsletter Editor & EAA TC www.aeronca.org Actively supporting Aeroncas every day ----- Original Message -----
Subject: Re: Pietenpol-List: Continental Engine Mount BoltsI just re-checked the plans.... they say to "Ream for 7/16 dia. bolt". BUT.... my Continental Maintenance and overhaul manual calls for 3/8" diameterbolts. ALSO... I just went out to the shop and was looking at my A75 engine which is still bolted to a taylorcraft engine mount. It has 3/8" diameter bolts.I think the rubber cone bushings that you buy from parts houses would surely be the same no matter what airplane. I am going to purchase 3/8" bolts. And,I am making a note on my plans to change the bolt boss I.D. to 3/8". For the shank length I am adding the 1.5" plans dimension of the mount boss to the 1 and 19/32" dimension of the aluminum casting on the engine and another9/32" for the large washer on the nut end. (These #s come from my Continental maintenance and overhaul manual.) This totals........... 3.375" forshank length. So Chuck's shank length is correct.SUMMARY:bolt DIA = 3/8bolt shank length 3 and 3/8 inchWhile were on the subject... The bolts I am going to buy for the engine mount-to-firewall bracket should be 5/16" DIA and...1 and 7/16" shank length.Terry________________________________________________________________________________
Subject: Re: Pietenpol-List: Continental Engine Mount BoltsIn a message dated 9/18/04 11:55:51 PM Central Daylight Time, BARNSTMR(at)aol.com writes:>The plans Do say "Ream for 7/16" dia. bolt". The bushings I bought from AS&S probably were for 3/8" bolts, but 7/16" bolts did go through them without much effort. The engine mount washers washers from AS&S fit the 7/16" bolts perfectly. These washers are about 1/8" thick. I used 7/16" bolts.Chuck G.________________________________________________________________________________Date: 19 Sep 2004 22:06:10 -0000
Re: Pietenpol-List: First Flight Procedure
Re: Pietenpol-List: Extra Fuel Tanks
The man who gave the model A carburettor talk at Brodhead, Terry Oberer, hasa prop like that in his closet at Byrnes Mill, MO, he said Howard Hendersonmade it. He, Grant McLaren and Howard Henderson are close friends. Terryshowed it to me when I was at his house a while back.Dennis Engelkenjohn----- Original Message -----
