Pietenpol-List: Firewall question
Re: Pietenpol-List: Firewall question
I covered my firewall with a fireproof mat from ASS. and the top sectionwith a 1" insulated fireproofing. The inspector at sign off commented thateven without the extras, before burn thru of the firewall, with a wod plane,I would have some other things to think about. He would have been OKwithout it.Dick N.----- Original Message -----
Original Posted By:> Rick Holland
I used fiberfrax for mine.Jack Phillips>
Rick,There is a requirement for this. It's somewhere around .016", but I forget.Just remember it can't be aluminum.I didn't use insulation, only used a 90 deg bend on the straight sides and a"metal shrinker" to get an overlap of about 1/2" on the top curved surface.The curve came out great!walt evansNX140DL----- Original Message -----
> To: pietenpol-list(at)matronics.com> Subject: Pietenpol-List: Firewall question> > > Ordered a sheet of .016" stainless for my firewall and would like some> advice. Bingelis recommends placing insulation between the firewall> and sheet metal like Fiberfrax. What have you guys used for this and> how thick? Have seen several pictures that looked like the metal was> bolted directly to the 1/8" ply.> > Thanks> > -- > Rick Holland> > > > > > > > > ________________________________________________________________________________
