Subject: Pietenpol-List: Invitation: Hank Styne's Weiner RoastHowdy all,The attached is an invitation from Hank Styne to his 16th annual Weiner Roast at his place near Grandview, TX. Hank says the invite applies to all those whe were at the Tick Hill Fly-In. I talked to Max Davis and Jim Markle today and both are planning to be there. I'll see you all there.Terry________________________________________________________________________________Date: Mon, 27 Sep 2004 21:05:09 -0700
Re: Pietenpol-List: Minimum engine instruments for a Corvair engine
I am using a Grand Rapids Technologies EIS 2004. It's a digital unit thatmonitors, rpm, OT, OP, manifold pressure, OAT, 2 CHT's, 2 EGT's, volts, hourmeter, up/down counter, fuel flow, also has 2 aux channels for monitoringanything else you want. Small,compact, easy to read and has a ton of safetyfeatures.you can get away with OT, OP and tach only though.Keep in mind when you lay out the Piet panel.... the cabane X wires take upvaluable panel space. make sure no instruments are in the way of them... Ilearned the hard way after making a panel that wouldn't work.you could try an Air/Fuel meter to aid in mixture adjustment.... somethinglike that could be mounted in the front panel.DJ----- Original Message -----
Re: Pietenpol-List: "How I carve Propellers"
Original Posted By: "cgalley"
I would really like a copy too if there is a way to get it through thesystem. Can someone host it on a site?Hank J----- Original Message -----
RE: Pietenpol-List: "How I carve Propellers"
Hank,Its available here:- http://www.mykitplane.com/Planes/People ... rWonthaggi Australiahttp://www.cpc-world.com-----Original Message-----
Fw: Pietenpol-List: "How I carve Propellers"
Original Posted By:> "Peter W Johnson"
Thanks. It is much smaller that the other site (11,195) I re-savedusing the make smaller option and it is about 9,000 KB for the entire 134 pages. I believe some of the pictures have been left out. I have my smaller version posted on a web site. It will only be up there 2days. www.qcbc.org/HowIMakeProp.pdf But it still will take a long time. Cy Galley - Bellanca Champion Club Newsletter Editor-in-Chief & EAA TC www.bellanca-championclub.com Actively supporting Bellancas every day>>> ----- Original Message -----
RE: Pietenpol-List: Invitation: Hank Styne's Weiner Roast
Hey Tick Hill Gang,I would love to be there with you at Hank's but I have aShriner function that same day or I would fly the GN-1there for dogs and fellowship.Hopefully we will have some other events coming soonbefore the cold (below 90 degrees) weather settles inNorth Texas.Have fun.Mike KingGN-177MKDallas, Texas-----Original Message-----
