Pietenpol-List: oil & oil temp questions
The manual for the A-65 engine calls for 40w oil summer and 20w winter. Wouldthere be a problem with running Aeroshell 15w-50? I dont know anything aboutoil science.Also, I have noticed that my oil temp has dropped since air temps are going down.I'm wondering if it might be a good idea to make some baffle plates for coldertemps? I know that running to cold can cause carbon build up and increasethe chance of fouling plugs while making power changes. I'm thinking of acouple of perforated plates that would lay on top of the cylinders, inside theeyebrows. I dont plan on extreme cold flying but it would be nice to get outon good days. Dick N.________________________________________________________________________________
The manual for the A-65 engine calls for 40w oil summer and 20w winter. Wouldthere be a problem with running Aeroshell 15w-50? I dont know anything aboutoil science.Also, I have noticed that my oil temp has dropped since air temps are going down.I'm wondering if it might be a good idea to make some baffle plates for coldertemps? I know that running to cold can cause carbon build up and increasethe chance of fouling plugs while making power changes. I'm thinking of acouple of perforated plates that would lay on top of the cylinders, inside theeyebrows. I dont plan on extreme cold flying but it would be nice to get outon good days. Dick N.________________________________________________________________________________Date: Thu, 7 Oct 2004 16:42:46 -0700 (PDT)
Re: Pietenpol-List: Hard Wire Rigging
Subject: Re: Pietenpol-List: Hard Wire RiggingCarl,Thats the way we did ours... .080 stainless 304 solid wire from mcMaster-Carr. I have seen lots of Piets done this way. Heres a link to a picof ours.http://www.mykitplane.com/Planes/photoD ... =1959Terry B________________________________________________________________________________
Re: Pietenpol-List: oil & oil temp questions
Original Posted By: "Galen Hutcheson"
I should have added that my reason for asking is that I sold my Seneca and have some 15w-50 left over. I'd like to use it up.Dick----- Original Message -----
Subject: Re: Pietenpol-List: oil & oil temp questionsIn a message dated 10/7/04 6:23:45 PM Central Daylight Time, horzpool(at)goldengate.net writes:>Dick,I have the same concerns. My oil temp hardly gets above 140 on the cooler days. I think that's not hot enough. I'm curious what others have done.When it's below 50, I dress warm, and I can get at least 4 or 5 circuits in the pattern before my body heat is all gone !!Chuck G.________________________________________________________________________________
ChuckI put in 2.5 hr last Tue at 45 deg. I was mighty cold. My wife was nice enough to make a cover for the front cockpit. I'm going to install cabin heat and remember to throw the long undies into the truck.I'm also remembering to throw in the shotgun in also. The last few times I went to the airport it was too windy to fly, it became a grouse hunting day instead. On the oil thing, I have been running about 140- 150 deg on a 70 deg day. Last week the temp barely came up.Dick----- Original Message -----
Subject: Re: Pietenpol-List: oil & oil temp questionsIn a message dated 10/8/04 11:41:38 AM Central Daylight Time, BARNSTMR(at)aol.com writes:>I will try using duct tape over the hole in front of the J3 fiberglass nose bowl, to see how that affects the temp. I also like the idea of insulating theoil tank, maybe with fiberglass. Chuck G.________________________________________________________________________________Date: Fri, 08 Oct 2004 23:03:10 -0700
I'll give it a try too. I was running at 140 deg today on a beautiful mid 60's day.Dick N----- Original Message -----
Dick,We use Aeroshell 100 50w here in Florida year around. We had the Shellexpert talk to us this year and he said that 15/50 was exactly what you needup in that COLD country of the north. Of course, we don't know anythingabout cold down here but I remember his comments. Go ahead and use it.Went flying for 3 hours today for the first time since the weekly run ofhuricanes. It was nice to have some nice fall weather with blue skys andlow 80s.Ted
Thanks TedGood to hear you made it thru the hurricanes ok. It's time for the oil change and the weather is changing.Dick----- Original Message -----
