Pietenpol-List: rib gusset material??
builders,what is our best source of rib gussett material?? i thought aircraft spruce usedto sell 1/16" plywood already cut up but i havent been able to locate it. isthere something eles that works?thanks,much to learn in nc________________________________________________________________________________Date: Fri, 15 Oct 2004 06:11:23 -0700 (PDT)
RE: Pietenpol-List: rib gusset material??
Original Posted By: "Textor, Jack"
Re: Pietenpol-List: rib gusset material??
Subject: Re: Pietenpol-List: rib gusset material??In a message dated 10/15/04 8:04:05 AM Central Daylight Time, shamblin(at)hci.net writes:>Bill,It takes quite a sizable piece of 1/16" plywood to do the ribs, and there is always other places to use it, so don't be shy about buying too much. Here isa few links to some places I've heard about, although I've never bought any there. The last two are info.http://www.aitwood.comEdensaw Woods in Port Townsend, WA. 800-745-3336; http://www.edensaw.comhttp://www.hardwo ... om/Boulter Plywwod Corp.24 Broadway, dept. WBSomerville, MA 02145www.boulterplywood.comhttp://www.faa.gov/certification/aircraft/av-i ... ______Date: Fri, 15 Oct 2004 16:26:56 -0700 (PDT)
