Pietenpol-List: Pulleys, etc
Original Posted By: Jim Ash
Re: Pietenpol-List: Pulleys, etc
Santiago, de donde es usted? Su ingles is perfecto. Estoy listo volar un versionde un Pietenpol. Estoy trabajando en la pista. Mi email es: dcombs(at)Ltex.net.Escribemi, por favor in espanol. I necisito la practica. Adios and gracios. Saludos.Doyle ----- Original Message -----
Re: Pietenpol-List: Pulleys,etc
Original Posted By:> santiago morete
Hola Sanitago,You can form 1/8" 1x19 cable around a thimble, but it is difficult. That's whatI used for my drag and anti-drag wires in the wings and for the undercarriagebrading wires (I used the straight-axle, wire wheel design). I used standardthimbles and nicopress fittings. The 7 x 19 stuff is nearly as strong and mucheasier to work with. If you use the -16 sized turnbuckles, the turnbuckleswill break before the 7x19 cable will. If I were to do it over I would use7x19.Jack PhillipsNX899JP>
Santiago,Use the -22 turnbuckles with the 1/8 cable. I would also recommend performing apull test on your cable assemblies. The thimbles have a tendency to deform underload which would require readjustment after they've been in service for awhile.Pull testing will deform the thimbles prior to installing them on the airplaneand they won't need readjustment.Greg Cardinal ----- Original Message -----
Original Posted By: Antonio A. Racioppi
Antonio, usa su ingles en el net. Los miembros son muy buenos hombres y ellos vana interder su mensaje con poca ayuda. Es un placer conocerle y si usted meda su email, voy a escribirle solo y n uso el net por cortesia. Mi Piet estalista para volar. Necisito un instructor que tiene tiempo en un Piet. Tambien,necisito una pista que estoy construyendo ahora. Otra vez, gracias por su participacionen el Piet net. Adios and Saludos.Doyle ----- Original Message -----
Original Posted By: "Antonio A. Racioppi"
>From: santiago morete >Reply-To: pietenpol-list(at)matronics.com>To: pietenpol-list(at)matronics.com>Subject: Pietenpol-List: Pulleys, etc>Date: Fri, 29 Oct 2004 19:23:08 -0300 (ART)>>Thanks Jack!>What did you used (or recommends me) for the flying wires? I'm about to buy >cables, turnbuckles, etc. It is common practice to use -16 turnbuckles >whit 1/8 cable or should I use -22? Gracias.>>Santiago>>>--------------------------------->lugar.> Encontr ms informacin aqu.________________________________________________________________________________
RE: Pietenpol-List: Pulleys, etc
Hola a TodosMi nombre es Antonio Racioppi, vivo en Mercedes, Soriano, Uruguay, estoyconstruyendo un Pietenpol desde hace ya dos aos y estoy leyendo sus correosdesde ese entonces. He aprendido mucho de ustedes, les agradezco mucho.Ya que Doyle ha pedido que escriba en espaol he decidido hacerlo y ponermeen contacto, ya que mi ingls es un poco malo.SaludosAntonioHello to AllMy name is Antonio Racioppi, I live in Mercedes, Soriano, Uruguay, I ambuilding a Pietenpol for already two years and I am reading its mail thenfrom that. I have learned much of you, I thank them a lot.Since Doyle has requested that writes in Spanish I have decided to make itand to put on in contact, since my English is a little bad.GreetingsAntonio -----Mensaje original----- De: owner-pietenpol-list-server(at)matronics.com[mailto:owner-pietenpol-list-server(at)matronics.com]En nombre de Doyle Combs Enviado el: Viernes, 29 de Octubre de 2004 09:47 a.m. Para: pietenpol-list(at)matronics.com Asunto: Re: Pietenpol-List: Pulleys, etc Santiago, de donde es usted? Su ingles is perfecto. Estoy listo volar unversion de un Pietenpol. Estoy trabajando en la pista. Mi email es:dcombs(at)Ltex.net. Escribemi, por favor in espanol. I necisito la practica.Adios and gracios. Saludos. Doyle ----- Original Message -----
> To: pietenpol-list(at)matronics.com> Subject: Pietenpol-List: Pulleys,etc> > Thanks Mike. I have read that 1/8 1x19 should be used with> swaged end terminals and you can't form it around a thimble. Is that correct?If it is, is not an option for me (costs!!)> Saludos desde Argentina> > Santiago Morete> > > ---------------------------------> Encontr ms informacin aqu.> ________________________________________________________________________________Date: Fri, 29 Oct 2004 19:23:08 -0300 (ART)
