Pietenpol-List: Wire Wheel info
Several on the list have inquired about sources for wire wheels, etc.....Well, my spoked/mounted wheels arrived today from Buchanan's. Their great! I'veposted pictures on mykitplane.com. Before I have to answer any goofy questions....thebrake WILL NOT be mounted to 1/8" ply (as shown in the picture) andit will not just lean up against the spokes of the wheel (as shown in the picture)and it WILL have a brake disc (as NOT shown in the picture).....I justwanted to see about what it would all look like.....hey, use your imagination!Also, I'm painting (NOT powder coating) the spokes and rims gloss black to matchthe powder coated hub.....http://www.mykitplane.com/Planes/buildL ... neID52I've also posted a (rather large) document containing copies of the invoices forbrakes/tires/liners/tubes/wheels at:http://www.mykitplane.com/Planes/People ... eels.docIf that link doesn't work, go to mykitplane.com and look in the files area......Jim in Plano.....________________________________________________________________________________
Re: Pietenpol-List: Wire Wheel info
Subject: Re: Pietenpol-List: Wire Wheel infoWOW... Looks Great, Jim! ________________________________________________________________________________
Re: Pietenpol-List: weight and balance
Original Posted By: Richard Navratil
Yeah. Note that the empty weight is found by subtracting outthe weight of the oiland fuel on board at the time of weighing. At this time I had 4 qts of oiland 2 gallons of gas. Also 2 lb tare for the tail wheel. That's about 22 lbs.That's the difference.You then calculate the fore and aft CG limits by accounting for those factors attheir respective moment arms.Bert ----- Original Message -----
RE: Pietenpol-List: Wire Wheel info
Original Posted By:> Jim Markle [mailto:jim_markle(at)mindspring.com]
Jack,I will be using the same size wheels and straight axle. How far is your axle fromthe firewall? I will have the same braking system as Mike Cuy. I have aCorvair engine that is ready to mount and run. I have it on a test stand andsoon as I get the prop I will start a breaking in on the test stand. Alex Sloan -------------- Original message -------------- > > Going from 8" discs to 10" discs would increase your braking force by > 25%. Are you using a hand lever or foot pedals for your brakes? 150 > lbs is a lot of force to be generating, unless the pedals are really > well placed. You will need a pretty strong seat back to resist that > kind of pushing, too. > > I have 8" Cleveland disc brakes, with Matco master cylinders mounted as > heel brakes. As I said, I can hold it for a run-up at 1500 RPM, ON > GRASS. On pavement I have to do sort of a "rolling run-up". My wheels > are 3.00 x 21. Slowing down after landing, even on pavement, is not a > problem. I have a 4" tailwheel and when I pull back hard on the stick, > it pushes that little tailwheel down pretty hard and it acts much like a > tailskid. Mostly I use the brakes for slow speed maneuvering and > parking, and for the run-up and starting. > > I wouldn't worry too much about over-braking this taildragger. My tail > weight is pretty light (about 30 lbs, with the plane empty) but with my > big butt in the back seat and the marginally effective brakes, > nose-overs are not really a worry. You can figure a motorcycle weighs > less than the gross weight of a Piet by a considerable margin, yet they > typically have discs 10" to 12" in diameter. > > One other point about the big wheels - you need BIG chocks to hold them. > My usual technique for starting it if I'm alone is to chock it with a > couple of blocks of 6"x6" pine, prop the engine, get it to idling as > slowly as I can, then replace the 6x6's with a couple of 2 x 4' blocks, > which will just barely keep it still at idle. I climb in the cockpit, > get my seatbelt and helmet and goggles on, then just goose the throttle > and it hops over the 2x4's as easy as you please!. Note that most FBO > chocks are made of 2x4's, so I'm already planning to make a lightweight > set of tall chocks that I can carry with me when I go air-camping. > > Jack > > -----Original Message-----
Subject: Re: Pietenpol-List: Wire Wheel infoIn a message dated 11/16/04 3:15:46 PM Central Standard Time, jphillip(at)alarismed.com writes:>Jack,It's really great to hear you're doing well in your flight test period. However, I'm curious if you have done any crosswind taxi, with over 3/4 a sockof wind ? Did your upwind wing tend to stay considerably higher than the downwind wing ? It seems to me that your bunji's are too loose. That's the problemI had with the split gear bunji's...I could never get them tight enough. I now have spring gear on the split axle, and she handles like a dream. Ask MikeCuy about crosswind taxiing. Chuck G.________________________________________________________________________________
Original Posted By: "Mike Whaley"
Hi Chuck,I thought they might be too loose, but I checked with Mike Cuy and he saidit sounds about right. With the plane empty there is a gap of about 1/4"between the axle and the V blocks. Mike said that was what BHP recommended.Besides, that's about as tight as I can get them.The most wind I've flown in so far was a couple of weeks ago when it wasblowing 12 knots with gusts to 20. It was straight down the runway, but Idid have to taxi across it a couple of times. Didn't seem to be a problem.I'm not sure I would notice a little bit of lean due to wind, becasue myhangar is down a slope from the runway and I have to taxiacross that slopeto get up on the runway. It always feels about like I'm gonna turn over.I'm getting used to it, but it sure got my attention the first few times Idid it.Tomorrow's supposed to be 63 F with clear skies and no wind. I'm gonna skipout of work early and try to put another hour on it.Jack -----Original Message-----Jack,It's really great to hear you're doing well in your flight test period.However, I'm curious if you have done any crosswind taxi, with over 3/4 asock ofwind ? Did your upwind wing tend to stay considerably higher than thedownwind wing ? It seems to me that your bunji's are too loose. That's theproblemI had with the split gear bunji's...I could never get them tight enough. Inow have spring gear on the split axle, and she handles like a dream. AskMikeCuy about crosswind taxiing.Chuck G.________________________________________________________________________________
> Tomorrow's supposed to be 63 F with clear skies and no wind. I'm gonnaskip> out of work early and try to put another hour on it.Now, there's a guy who knows what priorities are! :)________________________________________________________________________________Date: Tue, 16 Nov 2004 22:48:58 -0800
I'm trying like crazy to keep as many lines as possible out of the cockpits andrun along the fuselage.I'm not sure if this is a good idea for my oil pressure tube and my water templine. Putting them under the covering makes them inaccessable, but I'm not sureif they need to be accessed ever.They're both hard lines so are a little hard to get around the vertical membersin the cockpits cleanly.I don't think they should run through the same conduit as my mag wires becauseof heat and possible leakage, but maybe screwd to the fuse skin somewhere??Douwe________________________________________________________________________________Subject: RE: Pietenpol-List: Wire Wheel infoDate: Wed, 17 Nov 2004 13:42:50 -0000
