Pietenpol-List: flying wires
Hey AllI've got the one piece wing mounted on the fuselage and am working on attachingthe flying struts. Will the length of the flying wires change drasticly as Ijocky the wing for balancing? I am planning on using cable clamps temporarilyuntil I figure it out a little closer.Dick N.________________________________________________________________________________
Re: Pietenpol-List: flying wires
Dick,Just went through this about a month ago. I had set up mine with cabanestruts straight up from longerons. Then found the weight too far aft.Moved the wing leading edge back exactly 3", and I think it was only about10 full turns on the turnbuckles on the wing struts. I used the longturnbuckles, which have alot of travel. If you are too, just make the cablegoing to the front fuse fitting slightly longer than the rear, just in case.I still had to remake the tube supports going from leading edge to enginemount over again ( about 1 3/4" longer).Still all this was the easy part. The hard part was remaking/modifing thecowling for strut clearance, and new holes for cross cabling and controlcable clearance.by the way, did mine all right to the plans, A-65 with engine mountextended about 2", and put in the nose tank (which saved me in the W&B.) Iweigh 210#waltNX140DL(north NJ)----- Original Message -----
Subject: Re: Pietenpol-List: flying wiresIn a message dated 11/5/02 9:56:15 PM Central Standard Time, horzpool(at)goldengate.net writes:>Dick, when I moved my wing back to get the C.G. right, I had to shorten two of them, and make two new ones.Chuck G.________________________________________________________________________________
Thanks to Walt and Chuck for the info. The answer is - I will temporarilyclamp the wires till the question is settled.Dick----- Original Message -----
Original Posted By: "John Carmen"
DNA: do not archiveIts-Bogus: do not forward to list--- MIME Errors --- A message with no text/plain section was received. The entire body of the message was removed. Please resend the email using plaintext formatting. NOTE! This error can also occur when the poster of the message has a specific type of computer virus. This virus WAS NOT forwarded on to the List. The poster should be informed of the potential problem with their system as soon as possible.--- MIME Errors ---________________________________________________________________________________
