Pietenpol-List: Fuel cut-off valve
Original Posted By: "cgalley"
Subject: Pietenpol-List: Fuel cut-off valvePieters,Am to relocate my fuel valve from under tank, center. Does anyone know of any rule, objection to locating this valve on the engine side of the firewall? give me your thoughts on this subject, pleaseCorky________________________________________________________________________________
Re: Pietenpol-List: Fuel cut-off valve
Normally, the fuel valve is NOT placed on the engine side. In case of fire, youwant to be able to turn is off. Fire will damage the valve and you might notbe able to turn it off so the tank continues to feed the fire.Cy GalleyEAA Safety Programs EditorAlways looking for ideas and articles for EAA Sport Pilot ----- Original Message -----
Subject: Re: Pietenpol-List: Fuel cut-off valveIn a message dated 3/6/2005 4:22:50 PM Central Standard Time, cgalley(at)qcbc.org writes:Normally, the fuel valve is NOT placed on the engine side. In case of fire, you want to be able to turn is off. Fire will damage the valve and you might not be able to turn it off so the tank continues to feed the fire.Cy GalleyEAA Safety Programs EditorAlways looking for ideas and articles for EAA Sport Pilot ----- Original Message -----
