Pietenpol-List: drag reduction
Original Posted By: "Dave Esslinger"
Chuck "baby oil" Gantzer wrote->Working on 'Drag Reduction Mod' on my plane.>I'm cutting foam airfoils for all the round tubing, then cover it with >UltraCoat>model airplane heat shrink covering.You know there is an easier way to do this, right? The ultralight guys came up with a molded plastic streamline "tubing" that slips on over round tubing. It's available through the ultralight supply houses in two different sizes for two different ranges of steel tube sizes. It's paintable, and of course can be slipped off the steel tube if need arises later.Oscar ZunigaSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________Date: Mon, 16 May 2005 04:28:49 -0700
