Pietenpol-List: Step
Original Posted By: Chris A Tracy
Subject: Re: Pietenpol-List: gluesWe've used it on free-standing laminated radius stair stringers and it presented a problem with it's expansion that had to be compensated for. Something to be considered. Extremely strong for those needs, howeverWalt Snyder ________________________________________________________________________________Date: Sat, 9 Sep 2000 20:34:31 -0700Subject: Pietenpol-List: Step
Re: Pietenpol-List: Step
Original Posted By:> Chris A Tracy
I'm planning to go this route, but will probably box the step in withaluminum. Careful where you put it though. I put a cutout under the seatin the ply side and found the location was useless once the center wing wasmounted. Looks like about 12-16 inches behind the rear seat back workswell for me. Just about done one laminated ply spar. The 5' sections of plywood werescharfed on a 45deg angle with 3 1/2" wide scharfs. The second layer ofply centers over the 1st layers joint. Still have to put on the fir stipsto bring out the thickness to 1", (using 1/4" baltic birch ply for webs)and the attachment areas will be built up with another two layers of ply. Wayne Sippola, Winnipeg----------
Subject: Re: Pietenpol-List: Lift StrutsThe struts for my first aircamper are made from 1 1/4 dia by .049 wall 4130 steel tubing from Aircraft Spruce. V sections made from low carbon steel sheet at a local fab shop and MIG welded (weld 3/4 inch, skip 3 inches and so on) onto the round for streamlining and column strength. These are installed without jury struts (I prefer the cleaner look) and they are working very well. There are 77 hours on the aircraft now. I had a structures engineer help me aith all this. ________________________________________________________________________________Date: Mon, 11 Sep 2000 11:40:52 -0500Subject: Re: Pietenpol-List: Step
Original Posted By: Jim Sury
RE: Pietenpol-List: Step
I've always wanted to see one with a stirup liberated from a well wornbronco saddle.sTeve E.-----Original Message-----
Original Posted By: Warren D. Shoun
"Michael King" This work well. I have it on my GN-1 and isvery handy. It slides back into the airplanethus no drag.Mike KingGN-177MKDallas, Texas----- Original Message -----
Original Posted By: Jay
ronics.com Re: Pietenpol-List:
04:14:23 PMCongratulations, this has to be the first idea transferred from asupersonic fighter to a slightly subsonic Pietenpol. Jay Sent by: To: pietenpol-list(at)matronics.com,Steve Eldredge owner-pietenpol-list-server@mat cc: ronics.com Subject: Re: Pietenpol-List:Step 09/11/2000 03:24 PM Please respond to pietenpol-list; Please respond to Jay What about "liberating" a rear seat folding footpeg from the back of amotorcycle? It's small, sturdy, and would/could fold up into aminimal,non-intrusive recess in the body, perhaps with a small sliding cover,when notin use? That way, it wouldn't interfere with any control cables andwouldn'tinduce so much drag while inflight? You'd have to brace it prettywell where itmounted on the inside, but it "should" work. The idea came to mewhile lookingat a guy climbing into an F-86 at last weekend's airshow...Jay TravisSteve Eldredge wrote:>> I've always wanted to see one with a stirup liberated from a wellworn> bronco saddle.>> sTeve E.>> -----Original Message-----
"Richard Navratil" The insert that you describe is what I'm putting in. I drilled a hole thruthe tubes to lock it extended or retracted with a pin. I'm mounting it tothe rear seat bottom.Dick Navratil----- Original Message -----
Original Posted By: "Egan, John"
My apologies to the fellows with dial-up modems. Here are a couple ofpictures of the front step setup. This step is installed in line withthe front of the front seat and ties in to the spruce brace that runsalong the top of the floorboard for the front of the front seat toattach to.Even with the step the front seat is not easy to get into, but I did notwant to cut a door in the side of the fuselage. Most of the loads inthe fuselage are going through the longerons in the area of the frontseat and I just did not want to cut them there for the convenience ofhaving a door. Gary Price has a set of plans for such a door but I'venot seen them.Jack-----Original Message-----
Original Posted By: chris cummins
You can use anything you like for the datum - just document it so youcan remember what you used. For aerodynamic purposes, the leading edgeof the wing works best, but that means anything ahead of the LE has anegative arm, so you've got to be careful when doing the math. I usedthe firewall, because it is easy to hook a tape measure to it. Again,everything ahead of the firewall then must have a negative arm, but ifyou're careful, that's not a problem. I then added in the distance fromthe firewall to the leading edge of the wing and calculated my CG as apercentage of the wing cord to establish the CG envelope.Be sure you weigh the airplane in level flight position, preferablyeither inside a hangar with the doors closed or on a perfectly windlessday (you'd be surprised how much a 10 mph wind will change the readingon your scales). If at all possible, use certified aircraft scales(your local FBO almost certainly has a set that he would loan you). Ifirst weighed mine with bathroom scales, then found that my initialweight was off by over 75 lbs when I finally used certified scales. Puteach wheel in the cetner of the pad on the scale - if the wheel is offto one side it won't read accurately. Remember empty weight includesunusable fuel, but no oil in the engine.Jack PhillipsRaleigh, NC-----Original Message-----
Original Posted By: Benny Bee
Subject: Pietenpol-List: Step> Hi Guys,> > Here is how I did my pilot step. I wanted to have it totally > recessed, but I > had too much going on inside, so I had it stick out some too. > Pictures > attached. > > Dan Helsper> Poplar Grove, IL.> > > > > **************Wondering what's for Dinner Tonight? Get new twists > on family > favorites at AOL Food. > (http://food.aol.com/dinner-tonight?NCID ... 0000000001)> ________________________________________________________________________________Subject: RE: Pietenpol-List: StepDate: Wed, 21 May 2008 07:03:47 -0400
Subject: Pietenpol-List: StepHi Guys,Here is how I did my pilot step. I wanted to have it totally recessed, but I had too much going on inside, so I had it stick out some too. Pictures attached. Dan HelsperPoplar Grove, IL.**************Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food. (http://food.aol.com/dinner-tonight?NCID ... 0000000001)________________________________________________________________________________Date: Mon, 19 May 2008 14:36:12 -0500
Tom,Take a look at HYPERLINK"http://www.cpc-world.com/images/IMG_046 ... PG.jpg.You can see the rudder cable (green test wire) goes underneath the step.CheersPeter. _____
Original Posted By: Mike Townsley
Harvey,There are indeed two pulleys in that location, one for the rudder cable; theother for the tail wheel cable. Check out HYPERLINK"http://www.cpc-world.com/new_card_image ... 13_JPG.jpg for a better view.CheersPeterWonthaggi, AustraliaHYPERLINK "http://www.cpc-world.com/"http://www.cpc-world.com _____
Subject: Re: Pietenpol-List: StepWhy does it look like an altar?Steve D----- Original Message -----
Harvey, Which bracket?Peter _____
Harvey,That was a bit of bent welding wire used to find the best position of thepulley!!CheersPeter _____
Pietenpol-List: Re: Mitsubishi engine run up with prop!
Finally was able to do a few tests with the engine mounted to the airframe andthe 76 x 42 prop..........pretty much ran like a dream! was able to get to 1950rpm. if i crossed 2000 rpm the engine would start to cough a little bit. Thestarter worked real well too.here is the youtube link.http://youtu.be/sp24Odus-oURead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Mitsubishi engine run up with prop!
Chris,That looks and sounds GREAT. What a great day for you.What thrust numbers didyou see? I believe you will start a new movement with that arrangement. Canyou say Mitsubishi Collage?Congrats,--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Mitsubishi engine run up with prop!
Re: Pietenpol-List: Mitsubishi engine run up with prop!
Original Posted By: jim_markle(at)mindspring.com
It pulled 280 lbs.....at 1950 rpmRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Re: Pietenpol-List: Mitsubishi engine run up with prop!
Original Posted By: Chris Rusch
That's excellent! Was that a scale? If so, what was the reading? (I couldn'tread those hand signals!)Congratulations on a VERY nice sounding engine too!JM------Original Message------
Very nice!--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Mitsubishi engine run up with prop!
Looks and sounds great, Chris! Did the guy in the back say "275?"Gary-----Original Message-----
Chris:You should be congratulated by a great number of Pietenpol Wan-bes.I will be one of them.The top end is an easy cure to get power at full throttle, without burning valves.due to a lean mixture. With the prop shaft extension, a smooth look and anexcellent air flow will be a result.What cooling radiator do you use, and where is it placed ? If you keep a good airspace between the top of the radiator and the bottom of the wing, it will giveyou added lift where the air velocity is the greatest.I have a good 10 inches with a cross-flow radiator, flying feel is very differentwith the added lift, if interested in my installation give me a shout on myEmail,Pieti LowellRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Mitsubishi engine run up with prop!
Pieti Lowell wrote:> Chris:> You should be congratulated by a great number of Pietenpol Wan-bes.> I will be one of them.> The top end is an easy cure to get power at full throttle, without burning valves.due to a lean mixture. With the prop shaft extension, a smooth look andan excellent air flow will be a result.> What cooling radiator do you use, and where is it placed ? If you keep a goodair space between the top of the radiator and the bottom of the wing, it willgive you added lift where the air velocity is the greatest.> I have a good 10 inches with a cross-flow radiator, flying feel is very differentwith the added lift, if interested in my installation give me a shout onmy Email,> Pieti Lowellthanks!After looking over your plane at brodhead, i mounted my radiator the same way.i had a custom aluminum crossflow radiator built for 250 bucks. weighs only 8lbs.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Mitsubishi engine run up with prop!
Original Posted By: "Larry Morlock"
dfwplt wrote:> That's excellent! Was that a scale? If so, what was the reading? (I couldn'tread those hand signals!)> Congratulations on a VERY nice sounding engine too!> JM> > > ---Thanks,it was 280 lbs.........Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
I have a question on CG limits. I have just completed the weight and balance calculations on my Pietenpol (Model A engine, one piece wing, see attached). My CG is within the limit of no more than 20 inches behind the wing leading edge - just barely. Is there any value to moving the wing back another inch so it has some margin ahead of the 20 inch limit?Here's the numbers I calculated:Empty weight with oil and water - 710 lbsCG with 200 lb pilot and 10 gallons of fuel - 19.9 in behind LECG with 170 lb passenger - 20.1 in behind LEThe cabanes are already 2.5 inches back from vertical. Theoretically, I am OK with the wing as it is, but would it be better to have it more toward the center of the allowable CG range?Appreciate any thoughts. Larry Morlock________________________________________________________________________________Subject: Pietenpol-List: Re: Mitsubishi engine run up with prop!
Original Posted By: "Scott Knowlton "
Looks and sounds great, Chris! You have a right to be proud of that!--------Billy McCaskillUrbana, ILtail section almost done, starting on ribs soonRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Original Posted By: "Chris"
Anybody that has incorporated a step...I have found that my Piet has grown a larger tail wheel with each new iteration.And I started this airplane originally when I was about 30. Being 50 now hasshown I am less flexible than before.SO...to put a step under the back seat...I can see it would mostly be a semicircularcut out in the ply for a foot. Did you use any provision such as a tapereddoubler so the fabric is shaped much as the surrounding area. In other wordsjust attaching the fabric to the cutout would make a valley in the side ofthe plane. Thoughts? Solutions? What did you do?Ezra StilesSent from my iPhone________________________________________________________________________________
JohnDan Helsper has a step. Looks like he added a chunk of wood for the fabricto glue onto. I bet it is designed to be just behind the fabric. Can't bethat hard to figure out how the fabric will lay along the side by using along stick. http://westcoastpiet.com/images/Dan%20H ... ep.JPGPaul Poulin has a step too. It also appears to have a wood frame.http://westcoastpiet.com/images/Paul%20 ... _051.JPGIf your looking for something different.Mike Groah has a step but it is a blade sticking out the side.http://westcoastpiet.com/images/Michael ... 40.JPGGary Boothe has a loop type of stephttp://westcoastpiet.com/images/Gary%20Boothe/images/Step_-_1.jpgAt the lower left edge of the picture you can see the step bolted onhttp://westcoastpiet.com/images/Gary%20Boothe/images/IMG_0071.JPGThis is the other side.http://westcoastpiet.com/images/Gary%20 ... --Original Message-----
Ezra,As you can see.....tapered doubler. You mentioned that your tail wheel has grown larger with age, but no mention of your waistline. You might consider beefing-up the longeron to hold the extra weight :O)-----Original Message-----
