Original Posted By: "Egan, John"
Pietenpol-List: Seat Belts
RE: Pietenpol-List: Try to wipe that smile off my face!
RE: Pietenpol-List: Seat Belts
Re: Pietenpol-List: Seat Belts
Subject: Re: Pietenpol-List: Seat BeltsJohn: I mounted my belts from a suggestions in an old Buckeye Piet News.I put a 1x1x2" piece above the lower longeron at the attach location,then a U strap around the lower longeron with a bolt threw the addedblock above. Then a strap from the threw bolt, threw the ply seat bottomwhich I will attach the seat belt. The inverted U strap to the addedblock above the longeron so as to not have to drill a hole threw thelongeron. I'm going to add a head rest as a routing for the shoulderharness. This will locate the sholder belts higher and cover the attachcable that I will run back to the tail wheel bolt. The front belts willhook up to eye bolts running threw the floor board, ash crossmember, and14g steel strap. Front shoulder belts will attach to top cabane area alaBill Ruewe I scrounged my belts at the Osh. fly market. Leon S. In Ks.giving to the Red Cross.________________________________________________________________________________Date: Fri, 02 Sep 2005 14:44:14 -0400
